testing for gas leaks using a bubble tester
paul wilderness
19 hours ago, nottheone said:
The op stated he was asked to light the cooker, does that mean the oven or the smallest ring on the hob ? Would this matter and if not why would the guidelines say small burner / pilot light ? An oven would use many times more gas than a pilot light.  Also what is the problem with metric pipe  ? As far as I can see nothing in the BSS says you cant use it or am I wrong  ?
Bubble tester
It suggests a small burner/pilot light as when the bubble tester button is pressed all the gas flows through the small ‘tube’ dipped in the fluid, severely restricting the flow which might prevent a large burner from lighting, or possibly the large number of big bubbles might force an over full test fluid out of the test chamber up into the gas pipes.  Neither is wise.  So just enough flow for a steady stream of little bubbles to show the tester does test.  -  I light the smallest ring, wait for the ffd to activate then turn the ring to it’s lowest setting, then press the bubble tester button to ‘test the tester’.  Then turn off the ring, and use the tester to check for leaks.
Metric pipe
The Regs used to require ‘thick’ wall thickness pipes, which was not easily available in metric, but imperial pipe complied, so as a ‘rule of thumb’ imperial pipe was specified.  However so long as the min wall thickness is achieved (from memory they reduced the requirement so standard metric pipe now complies) metric is ok.
Edited by Chewbacka
Indeed -  it made a mockery if C&RT (BSS) insisted on differing sizes to the RCD so the BSS was amended to fall inline with the RCD,
