WotEver Posted August 22, 2020 Report Share Posted August 22, 2020 4 minutes ago, TheBiscuits said: Is it not like varnish then? You should have used the other one ... Well, now that you mention it... @Sassy Lass, when you do try one or more of them out please let us know your favourite Link to comment Share on other sites More sharing options...
AndrewIC Posted August 22, 2020 Report Share Posted August 22, 2020 On the aforementioned back door panels which had come adrift, it was apparent that the previous glue (I don't know what it was) had gone rock hard, and that it was the glue itself that had failed, rather than the bond between glue and wood or glue and steel. In the end I sacrificed a small multi-tool blade to get the remains off the surfaces. Link to comment Share on other sites More sharing options...
WotEver Posted August 22, 2020 Report Share Posted August 22, 2020 34 minutes ago, AndrewIC said: On the aforementioned back door panels which had come adrift, it was apparent that the previous glue (I don't know what it was) had gone rock hard, and that it was the glue itself that had failed, rather than the bond between glue and wood or glue and steel. In the end I sacrificed a small multi-tool blade to get the remains off the surfaces. It could have been polyurethane. Because it foams some folk think it has gap filling properties. It doesn’t, it’s very weak in the foamy bits and joints must be well clamped until it has set. Link to comment Share on other sites More sharing options...
