As the title suggests, does anyone know of a good mobile marine mechanic in the Coventry area?
We are a Hawkesbury Junction and our starter motor is playing up. The motor justs cloncks when the key is turned as though it is jammed. It has done this in the past and manually turning the flywheel has freed it up. This time it isn't freeing up and hitting the motor with a hammer doesn't seem to help either. So it is probably about time it was replaced.
Check the security of the cable connections at the battery and at the starter and also any negative cable connections to the engine.
Use your multimeter to check the voltage at the starter when you try to turn the engine over.
