Crow Posted May 10, 2020 Author Report Share Posted May 10, 2020 3 hours ago, Halsey said: A bit late to ask this but once a good guard is fitted are you going to be OK in locks Well the gunnels are wider. ,by the time a guards on ,the old tires as fenders will still be protruding more,Itl be no worse than having a Tupperware ,and it’s on the steering wheel side,everything I’ve done on it is unconventional,it must be the only extended water bug ,with a inboard diesel and a z drive,but it’s worked ok for a few years 1 Link to comment Share on other sites More sharing options...
Crow Posted May 24, 2020 Author Report Share Posted May 24, 2020 Well ,carver cascade is fitted and working well, that was a cheap fix to get a balanced flue water heater with no long chimney/ flue just need to grind and sand some radius on the edges of the guard 2 Link to comment Share on other sites More sharing options...
mrsmelly Posted May 25, 2020 Report Share Posted May 25, 2020 11 hours ago, Crow said: Well ,carver cascade is fitted and working well, that was a cheap fix to get a balanced flue water heater with no long chimney/ flue just need to grind and sand some radius on the edges of the guard Exellent job. They are great bits of kit. Switched mine on ont motorhome ( 27 years old ) for the first time after the winter and it fired up and runs sweet as a nut. Link to comment Share on other sites More sharing options...
Crow Posted May 25, 2020 Author Report Share Posted May 25, 2020 Yes it struck up as soon as I switched it on, I’ve put a bit more lagging on the tank ,turned it off at 10 pm last night and it was Luke warm this morning at 9 ,well happy at £75 for it and £40 for a gas test ,found a leak on the hob and grill while we were at it Link to comment Share on other sites More sharing options...
