Jrtm Posted September 26, 2019 Report Share Posted September 26, 2019 Quick question is there a way to put decompression leaves on the top of a jp2m if there on the side? Link to comment Share on other sites More sharing options...
Jrtm Posted September 26, 2019 Author Report Share Posted September 26, 2019 Reason I ask is if engine has to be stripped and top end rebuild, new pistons, liners and rebuild heads wanted to know how easy it is to swap the decompression button on the side to a lever on top makes starting easy as can use bit of string rather than a foot Link to comment Share on other sites More sharing options...
john.k Posted September 28, 2019 Report Share Posted September 28, 2019 The lifter is a simple spring loaded plunger on a rocker cover,no reason why you couldnt have both.......I expect the covers simply swap over.....and if you have a minimum of engineering gear,you could make your own modification of the existing covers. Link to comment Share on other sites More sharing options...
BWM Posted October 2, 2019 Report Share Posted October 2, 2019 Source some rocker covers with the decompression assembly on, job done. Link to comment Share on other sites More sharing options...
Jrtm Posted October 2, 2019 Author Report Share Posted October 2, 2019 Ok cool didnt realise it was that simple! Makes it easy, be next job after my national work Link to comment Share on other sites More sharing options...
