LadyG Posted October 1, 2019 Report Share Posted October 1, 2019 10 minutes ago, Alan de Enfield said: Just make sure that you use 'heavy' enough cable for your 12v wiring. Recommendation is at least 1mm squared per metre (distance from fridge to batteries). Or, follow the guidance graph in the Waeco owners manual Yep, the electrician will have to sort it out, I suspect the transformer was added as an afterthought, so there may/may not be wiring to the main leisure battery bank. Link to comment Share on other sites More sharing options...
