james13
Everything posted by james13
  1. Hi I used these stuck them on with some CT1 got them off Ebay 5 mm White Foam PVC Sheet A3 Foam PVC Sheet Board 10 sheets Have cured the condensation £25 for 10
  2. Very strange it is a pdf online all i do is save to desktop open it and the storing on land condition has gone but is still there on the online pdf
  3. Looking at the documents online the condition stating it has to be laid up ashore as previously mentioned is there but if when i save a copy to my desktop the condition has gone but it still shows on the online document
  4. Well i have just been trawling through all the documents and i have not found anything yet that says these conditions do not apply
  5. Hi I have been insured previously with Haven Knox Johnson and this year when it came to the renewal i did auto renew and the company i am now insured with is called MS Amlin On checking the policy schedule it states that a condition of the insurance is that the vessel must be laid up ashore between and including the following dates 01-November and the 31-March how ridiculous is this??? Check your policies people I have contacted the insurers for clarification
  6. Thanks for the replies i will just use the 30 amp controller for now as i am a bit tight
  7. Hi I have two 300 watt @32 volt solar panels and i have been given a 30 amp 100voc mppt controller. Would the 30 amp controller be ok? but if it is a bit on the small side would it still be ok to use it and accept that i would not get the full output from the panels until funds allow me to buy a bigger one
  8. there was a video on you tube showing how to fit 3/8 fittings to a 10 mm bubble pretty easy did it on mine and the pipe fits proper now Try this link there are 3 videos in part 3 he does the conversion
  9. there was a video on you tube showing how to fit 3/8 fittings to a 10 mm bubble pretty easy did it on mine and the pipe fits proper now
  10. Shame about the keelblack i quite fancied that maybe in a few years reviews permitting
  11. Thanks i will have a loot at the Dacrylate site and see whats what
  12. So would you say it has held up well for a year then would you trey it again under better conditions
  13. Did yours have comastic on and how is the keelblack holding out. have read a bit about keelblack but it sounds a bit new/untested and to good to be true
  14. No something to do with the EU and the chemicals in comastic
  15. Hi Will be taking the boat out for blacking soon and it was previously covered with comastic and i understand you cant get this any more.Has any body any experience blacking over this and what did you use i don,t fancy having it blasted back to bare metal ..Any suggestions
  16. Thanks for the replies think I will go for a kipor IG 1000
  17. Just Power tools mainly Battery charger and small stuff the size is more than I need really but it seems like a good buy with it being dual fuel
  18. Hi I am on the look out for a generator and have come across these https://www.generators-direct.co.uk/camping-and-caravan/p1pe-p2000ilpg-1800w-dual-fuel-inverter-generator Seems like a new brand. dual fuel,Hyundai engine, 1800w £449 delivered. Does any body know anything about these? have looked on the P1PE website but they don't even show them
  19. Yes they did mine is a standard width split on the length if that makes sense
  20. Hi Got mine from a place in Yorkshire called apollo beds got the name off some one on this site cost @250 and is comfy try doing a search on the site to see what pops up
  21. Hi I have a mixing valve mounted on the calorifier (surecal) Cheers
  22. Cheers both thanks for the replies i think i know what im doing now
  23. Hi I have a canaline 38 with a rubber hose that comes off the thermostat housing then reconects to the engine at the bottom near where the skin tank connects to the engine the pipe is doubled over and clipped so that water cant flow, i assume this hose is to conect to the calorifier. If so what is the best way to connect the hose to the calorifier would the water flow come out at the thermostat and back to the bottom of the engine if this is the case should i disconect the hose from the bottom of the engine unclip it so water can flow and then would it be best to connect the end to the bottom or top of the calorifier coil and use a fresh piece of pipe to finish the circuit back to the bottom of the engine? hope this makes sense
  24. Hi I wad advised it should be @ 10% size wise of your calorifier
