Steve@iwabss-limited.co.uk
Everything posted by Steve@iwabss-limited.co.uk
  1. Well that’s an interesting section. There are several occasions when a BSS will not comply with GSIUR and not only fail but also have the supply disconnected. The requirements for a BsS Cert on many vessels that are not in scope of GSIUR is simply compliance with the published ECPs applicable to that class of vessel. However where a vessel falls within scope of GSIUR, even if it complies with BSs ECPs it can be determined to be at risk or immediately dangerous. In which case the appropriate appendices of the. ads are acted upon and the GSR qualified examiner will follow the requirement of legislation and act accordingly. If you were a qualified BSS EXAMINER who was also GSR to CCLP1-B you would know that. As you are asking the question I assume you don’t know it. The difference then is that I am qualified, you are (or appear) not to be so qualified. Plenty of closet experts. In the event of an insurance claim attitudes and attentions are sharply brought into focus. You keep giving good advice, I’ll keep getting paid for correcting the mistakes of those who ask and listen to the wrong people. My work is warranted, legally undertaken, fully insured and regularly re-certified. Is yours?
  2. I am GSR Yes. Marine only. Also BsS Examiner. RCD doesn’t exist and hasn’t for 2 years. Pd 54823 is applicable on all ‘existing’ craft. 10239 and 10322 are new craft for certification to ‘Recreational Craft Requirements’.
  3. Read ECP 7.8.1. ‘ the requirement for inspection of pipework inspection is ‘where it can be seen’. ECP 7.9.1 considers ‘hoses’ which must be ‘accessible for inspection along their entire length’. I’m guessing you are not a BSS Examiner (certainly hope not)
  4. Yes that is correct. Pipework in the photos looks like 5/16” so if the Isolation Tap is staying that would meet the requirements of the BSS . So long as it can be inspected.
  5. If the oven is going to be permanently installed (not on wheels and able to come out for cleaning) then it should be on Copper pipe. Flexible hose when installed must be fully accessible for inspection at the time of BSS. I know that may be inconvenient bu it complies with Regs and BSS Requirements.
  6. Just adding to the request for a hands up! I am Gas Safe Registered for LPG installations and repairs on boats (Not caravans or LAV) and a Boat Safety Scheme Examiner too. I don’t post much on here because of some of the ‘clever’ comments you get from ‘educated do Goode’s ’ But I am happy to advise anyone on a Gas or Boat safety issue.
  7. Title: The Gas Industry Unsafe Situations Procedure – Edition 7.1 Date Revised: 10th December 2015 thought you said you were a gas Safe Registered Engineer with the same qualifications as me. If you are, log in to GSR and look up TB001
  8. Absolutely not. I would not do that.
  9. Hi MIke, thanks for your input. I was correct, it stands for Gas Installations Unsafe Situations Procedures. Also known as L56
  10. Hi Bod. There are are lots of different ones on the market. Simplest is available from Midland Chandlers and you simply take your gas pigtail out of the Cylinder and screw the gauge onto the end of the pigtail. Then put the gauge into the Cylinder outlet, tighten up the pigtail and gauge and turn the gas on. The gauge will register pressure. Now turn the Cylinder off and if you have a leak the pressure on the gauge will reduce to zero (depending on the severity of any leak it can be slow or fast). Cheap and unsophisticated compared to an Alde Leak Detector but they do the job. Of course if you have a leak indicated call a gas engineer to check your system out. That depends. When did they move the marina I'm moored in?
  11. Not a very good one by the sound of you!
  12. Time served? Yes, CGLI? Yes in All my practicing disciplines which are not restricted to gas alone! Apprenticeship? Yes (the 4 year one). That's cos I'm welshWelsh And I have a stammer General engineering appreciation of someone who is not qualified who thinks they can tell the qualified engineer where he is wrong. Most dangerous situations are created by one.
  13. Read the thread, I didn't start it.
  14. So long as you are walking away dealing how clever you are it was all worth it!
  15. Ahh. Well there you go! The expert amateur shoots his other foot off. As as much as I like this sort of sport, it gets rather tiresome after a while. Education ....... The GI(US)P also known in the trade by Bona Fide Gas Engineers (which you aren't) as L56, is the Gas Installation (Unsafe Situations) Procedures. That is what Gas Engineers are guided by when we come to a boat that has been 'cobbled together' by a well meaning expert amateur when we Disconnect the supply, issue a warning notice, if necessary report the issue to the HSE and then walk away, content in the knowledge that we have strengthened the gene pool by prolonging its population by one (at least) amateur expert to help all us qualified guys out! Done with you now, only to offer one last bit of advice (which you are bound to ignore)....... Never, ever, enter into a battle of wits with someone when you are so obviously half armed! you will get that in a bit TTFN!
  16. Familiar with eh???? Have to tried GI(US)P? look it up. Only get smoke screens after fires. I refer to my earier statements
  17. Well I just examine them and have provided the wording on Page 3 of the certificate. For the record, I don't need a bubble Tester in any vessel to test the gas as I am a qualified Gas Safe Registered Engineer. Are you? As for drumming up business, I don't want it, in fact, if all of the clever people giving advice on here like you actually knew anything or took the time to read the standards, you would find that BS10239 mandates the installation of 'a simple means for the user to test the system for leakage' which is not necessarily a bubble Tester. The only BSS examiners actively promoting the installation of Bubble Testers are those few who wish to force people into buying somethingwho do not hold GSR or ACS qualification in LPG who want to continue testing liveaboard boats (which they are prohibited from doing unless a Bubble Tester is installed). There are cheaper, simpler, idiot proof options available that can be fitted by anyone (such as a gas gauge) without affecting the validity of their BSS certificate! Have you been promoting or advising those? Probably not because you are a practicing 'Non Gas Safe Registered, Non ACS trained, Non CCLP1-B 'expert' who is actively helping good people do dangerous things with absolutely no compunction of your own liability! as I stated earlier, you can't design out an idiot!
  18. I can assure you that every BSS records the use of either a manometer or bubble Tester by the examiner. Having been involved in a number of investigations in the past I can assure you that no stone is left unturned by the MAIB or HSE and whosoever is responsible for the incident/accident would be prosecuted by the authorities. If an examiner is responsible we are all insured for PI. Most people undertaking DIY generally don't! The risk is theirs. If in doubt, seek the advice of a professional, after all, advice is free and could save a life. Well it's true what they say, you can't design out an idiot!
  19. The third page of a bss certificate states this. About the BSS Certificate The BSS Examination Report (inc. receipt-style BSS Certificate) From April 2013 - This document reports the findings of your boat's BSS Examination which is to satisfy the question: 'Does your boat meet all the applicable navigation or harbour authority minimum safety requirements on the day it was carried out?' The question has three possible answers: Yes - In this event, the report can be considered a receipt-style certificate. It indicates that your boat met all the applicable minimum requirements on the day of examination. You should take note of the expiry date in forward planning your next BSS examination. It is the entry of this information on the central BSS database, and not the BSS Examination Report, that will be used by your boat licensing body as evidence of your boat's BSS certification status. Keep the certification information with the boat's records and pass it on if you sell the boat. Yes, but some advice checks did not pass - All the information in the paragraph above applies; however the examiner found advice check items that could not be passed (marked with an 'A'). Although privately-owned boats do not have to comply with advice checks to achieve BSS certification, each one represents best-safety practice and meeting them all is highly recommended. Any listed in the report may be material to the vessel's insurance and the boat owner's duties under the law of occupier's liability. No - Checks marked 'R' for 'required' have not passed and these items must be addressed to achieve BSS certification. Again as above, addressing any issues linked to any checks marked 'A' included in the report are highly recommended. Full details of what has failed, why and what must be achieved will be provided by your examiner. Warning notices - these are issued when the examiner has found, or has cause to suspect, that your boat presents a significant and immediate risk. You should arrange, or carry out, works to make the boat safe as soon as possible. The general nature of the risk and any checks associated with Warning Notice will be identified by your examiner. About the BSS Examination and its limitations Please note: the BSS Examination findings, and examination report, relate only to the facts observed at the time of the BSS Examination. It is not evidence of compliance with the navigation authorities' requirements at any other time. The owner's on-going responsibility: it is crucial to maintain the vessel in good condition in accordance with the safety requirements; and, any other licensing, registration or mooring conditions of the relevant navigation or harbour authority. The validity of a BSS pass result may be affected and can be cancelled if the vessel is not properly maintained; and/or non-compliant alterations are made; or if a hire boat or other type of non-private boat is examined against the 'private boat' category of BSS checks. A BSS examination and examination report relates only to the relevant version of the BSS Examination Checking Procedures published on boatsafetyscheme.org. Depending upon the nature of the specific check, the examination may be confined to items that can be seen, reached or touched. A BSS examination is not a full condition survey, nor is it an indication that the vessel is fit for purpose. For example, it does not cover the condition of the hull or deck, the integrity of through-hull fittings or the stability of the boat and it isn't the same as having your boat serviced and doesn't check its general mechanical condition. Prospective boat purchasers are strongly advised to satisfy themselves about all aspects of a vessel's condition by commissioning a pre-purchase survey before committing themselves to becoming new owners. Some surveyors are also authorised BSS Examiners and may be willing to carry out a BSS examination whilst surveying the craft if contracted so to do. Please note the text text in Bold Underlined. The standards for LPG installation on vessels up to 24m in length are BS10239 and PD54823:2016 Thanks
  20. If you go ahead and fit a Bubble Tester in this arrangement you will at the very least immediately invalidate your BSS Certificate (Take it from me, I am a Gas Safe Registered BSS Examiner). Not only that but by installing the Bubble tester in line with your LPG gallery it will act as a choke and restrict the gas flow to your appliances when they are all running. You have 18Kw power in your appliances. Bubble testers cannot be installed in line where appliance ratings add up to more than 12Kw. Choking the gas may seem that they won't burn quite as fierce as they should, in actual fact it means that the gas will not burn as it should and it will produce deadly amounts of CO. Please seek professional advice. There are ways to install a bubble Tester in systems with over 12Kw appliance ratings but they must be installed in an 'isolated branch' arrangement. And with regards to insurance, the BSS have a record of every vessel with a Bubble Tester so in the event of an accident or worse a fatality, the resulting MAIB investigation will look to find out who installed it and when. And if done by other than a GSR Engineer certified to CCLP1-B then your insurance will be invalid. Happy to help if you want more advice.
  21. Hi Cait. If you are the Cait that I visited in London earlier this year to look at working on your boat please call me, I may be able to help. Steve
  22. A quick check on BSS database shows she was examined in 2016 and passed with no Advisories. If you are keen I would recommend a survey (I am a BSS examiner but not a surveyor). But be careful which surveyor you choose. I know a few who are under investigation at this moment and one who chose to settle out of court. Offline I can recommend a few who are good & reasonable but as ever. Caviat Emptor.
  23. The requirement for a Gas Inspection on a boat is simply broken down as below: Privately owned and operated boat (Live-aboard or not) with LPG - Only requires a Gas Tightness Test as part of the BSS Certification every 4 years (but would benefit from an optional annual inspection). Privately owned and rented out (Live-aboard or not) with LPG - Requires a Gas Safety Check annually for all appliances & Landlords Certificates.. Privately owned under 3rd management (shared Owner) with LPG - Requires a Gas Safety Check annually for all appliances & Landlords Certificates. Hire Fleet Vessels - Require a Gas Safety Check annually for all appliances & Landlords Certificates. Hope this helps. Steve Williams - GSR Engineer (marine LPG)
