cudnriach
Everything posted by cudnriach
  1. Vitrifigo do an auto change over fridge that uses 12vdc or 230v ac if it is available.
  2. I was a Sea Cadet at Wakefield. The Submarine turned up mid Parade night , que stampede outside I believe the date was in 1963 as I was in the cadets 1961 to 1967 and possible I am on the motor boat as guide as I was picked to help. Nobody got inside as I remember. The two Seamen with white jumpers are crew members. The buildings behind came down in 1964/65 and the motorboat "Delta?" left and went to Leeds in 1964.
  3. RM5310 has a battery in the igniter button. Insert small flat blade screwdriver into the centre of the button push in slightly and turn 90 deg anti clock to release. Be gentle its soft plastic. Jet in a fridge is very fine. so several attempts to light often needed. The Temperature dial has to be pushed in to allow gas to flow until the thermocouple can hold the safety device open. Quite often makes sense to light the cooker first o check gas operation and bleed out any air inthe pipes.
  4. Try Venta ILS34 touch switch units. 135 mm x 70mm surface mount. web www.ventaauk.com 01962884444
