The normally held view is that the anchor is there largely to secure the end of the chain, the chain should have sufficient weight to create a significant drag to hold the boat and to form a spring (the effect of trying to lift the heavy chain off the bottom will hold the boat in a tide or current). In that case the chain appears too light w.r.t. the size of the anchor. Forces generated when the boat is static are quite low, in a river related to the drag in the current, in a seaway you must add the bucking of the boat in waves. You can probably get away with an anchor, a short length of chain to hold the stock of the anchor on the river bed, and plenty of rope, in a river; chain comes into its own in a seaway.
If you ever wish to use the anchor to serve as an emergency brake you will need really substantial fixings and much thicker rope. The snatch force, if the anchor bites on anything solid, slowing the boat from maybe 3 knots in a strong current will be related to the weight of the boat (obviously) and to the elasticity of the rope.
If the rope has zero elasticity the snatch force is, in theory, infinite. If the boat is decelerated over a reasonable distance the snatch force is WxD/g where W is the mass (weight) of the boat, D is the deceleration and g is the gravity constant (in the same units). For example if the boat is slowed at a deceleration of 32ft/sec/sec then D/g is 1 and the snatch force is perhaps 18tonnes. In the case of stopping the boat dead from 3 knots in 2 seconds the average snatch force will be about 1tonne, (actually increasing from zero to about 3 tonnes as the rope stretches and takes up the strain) and the distance travelled (stretch in the rope) will be about 4metres. So if you have 20metres of rope it needs to be able to stretch by 4 metres. This is 20%, about the limit for nylon or polyethylene rope. The rope thickness needs to be at least 14mm to withstand this breaking strain.
