TheBiscuits
Everything posted by TheBiscuits
  1. Well yeah, the cloths were not usually fitted vertically ... Mind you for ex-working boat fugliness the BW blue tops take some beating. Historically accurate in a couple of cases, but not a look that aged well!
  2. You know the one about the wooden boat with a wooden engine ...
  3. The Rochdale one has the advantage that cars do stop for it. For some odd reason a couple of feet thickness of concrete and steel lifting up in front of them gets more respect than a plastic red and white tube slowly descending ...
  5. Why would you do a hundred mile cruise in a fortnight and then return to the same place you started? If it's a home mooring then that pattern is reasonable, but in that case you wouldn't be getting a warning letter. If it's not a home mooring, then you should be getting a warning for this pattern - it's given as an example of what not to do in the guidance.
  6. If they can't read the A for advisory or R for requirements on the checklist I'm not sure how they read all the rest of the thing!
  7. Yes. Easily. Whether or not the prediction turns out to be correct is the gamble you'd be taking with the enforcement process ...
  8. I flogged my old system to a mate for exactly half of what it was then available for at retail. Suited him and suited me at the time. If flogging it on eBay or Facebook marketplace I'd probably have asked a bit more (2/3rds?) True, that's why I started out by seeing what the equivalent bits were available for brand new as a good starting point. That does of course require exact makes, models and specifications of the panels and the controller, and a list of what extras if any are included. I just sold the panels and the controller, but threw in free the resettable circuit breaker as it would have been too small for my new system. Helped him install it too, but then he is a mate.
  9. Wigan dry dock for a proper fix, engine can probably be sorted while afloat. Either free the rudder up with a sledgehammer and some plus gas or a blowtorch , or get a tow from someone to Wigan. As mentioned above, working on boats out of water is a pain in the backside but for some jobs it has to be done. Have you spoken to a good boat fettler or are you just assuming it needs craning out to sort it? Try Dan at RDE Narrowboat Services 07405 996310 see if he can help - he's mobile and covers the North West. Add a bit: you can get to Wigan Dry Dock, it's the flight itself that's shut and today there was an issue with the junction pound.
  10. Personnel changes mainly. In the last five years a couple of those who were there have passed away and others have left to go elsewhere. For some jobs I recommend Wheelton boatyard, but they are very limited on space so can't/won't have a boat on hardstanding for a few months, which the OP was asking about. Hesford marine is another place that might work, but due to the breach you can't get there from Lathom either!
  11. I get a regular look of misery from crewed boats when I'm single handing. Until we start working the lock and I'm doing three quarters of the work ...
  12. No hard standing at Crooke Marina, but the storage site and new moorings the other side of the bridge used to have a crane so may be worth an ask. I've stopped recommending Botany in recent years, despite it having used to be my first suggestion. Also, even if it seems a good idea the boat can't get there with the locks shut. From Lathom Junction I'd be asking Tarleton boatyard about availability, it's just the other end of the Rufford Branch.
  16. I think that's booked to certain staff salaries
  17. That's no excuse for instant tea ...
  18. I have both a gas cooker and a standalone single plate induction hob. Making a brew or cooking a single pan meal with sunshine instead of propane just makes sense - I don't see any point using gas when my MPPT is shutting itself off before lunchtime because the battery banks are full. Especially when we still have another 9 or 10 hours of daylight left ... A full 1.7 litre kettle takes 6 minutes to boil at the default 1200W setting, pulling just over 100A from the solar panels and battery bank (inverter efficiency losses). By my reckoning that's 0.12 kWh, compared to a standard 2.2 KW electric kettle that uses nearly twice that (measured at 0.2 kWh but comes to the boil faster.) It's usually been replaced before I need another brew, even on a dull day. The induction hob can be varied between 200W and 2000W in 9 200W steps so quite controllable, and has a built in timer function. It goes away in a locker when I have to start paying to make electricity!
  19. Oh it's not you then. T'other rusty would have known the answer is "How do you drive this thing?"
  20. You're the one with the smutty photos, but yes, that's the one I suspect! Hey @Russ T two fish in a tank, one says to the other ...
  21. Mine don't. Am I doing it wrong?
  22. Fill your boots. I strongly suspect that @Russ T used to be around 69 ... Sense of humour, experience, familiarity with forum regulars, posting style. If he is who I think he is, he's been both an offshore sailor and a liveaboard narrowboater for decades. If he introduces Dr Bob's fish jokes again I'll be completely convinced.
  23. Morlock speak. It translates to "not going" in unmangled English ...
  24. Congratulations Rebellion! I thought you preferred second place though 🤣
