ralphclaydon
Everything posted by ralphclaydon
  2. Hi I purchased a multi-tool from Aldi , seems a good bit of kit. Was wondering if anyone knows of another brand of replacement cutters which will fit the Aldi tool?
  3. My first fitout 54 foot trad. took me 5 years, the second fit out a 57 foot trad took 3 years, I know one person who said it would take 6 months, Coming on 6 years and still not in the water!!!
  4. Why don't CRT supply us with these proposed signs? We could mount them on poles and stand them in our cones! That way they have no excuse they did could not see the signs!!
  6. Hi Just a very late update. Since my last post i have had the batteries on charge 24/7. Due to other commitments have not been able to take boat out till last week. The Smart gauge read 100% when we started,Only cruised about an hour a day(Spent the week between Whilton and Blissworth). We used the 12v Fridge, and at night 240v TV for about 6 hours ,this sent the smartgauge down to about 93%. my wife used her 240v hair dryer on a couple of occasions! The Smart gauge never went below 80% all week, I checked the water level when we got back to mooring , they did not need topping up(Thats the first time they have been checked since i installed the Sterling Pro). It seems that the problem was with the way i had wired the battery bank after all! Thanks for your help
  7. Blimmy where do you find that sort of room on a narrowboat?
  8. Hi i have been looking on the AirLink site, The BT3231 ( 3600va, 230v x 230v ) would seem to be my preferred choice BUT the size of the case is given as H 355 L320 and W 355 seems very big to me! Thats 12" x 14" x14" high in old money! Has anyone got this model?
  9. If i was to purchase a galvanic transformer how would i work out what VA i required?
  10. I am sure that they moor in Stow Hill Marina!
  11. Batteries being collected for testing on Tuesday. They recon it will be a week to 10 days before we have results.
  12. Thanks Nick I will email them and see if we can get them collected! Thanks again
  13. Another update! Checked water after Equalisation for 4 hrs. No lose at all. Battery charger turned off, 12.10 PM 8 x 10w lights computer and TV (47V) turned on. Voltmeter 12.75v 12.40 PM Volts 12.40 1.20 PM Volts 12.3 3.00PM Volts 12.34. 4.00PM Volts 12.10 -12.15 5.00 PM volts 12.00 The batteries are still not taking a charge, but they don't seem to be using water ether!!
  14. Thank you I will check the water levels tomorrow.
  15. Hi Finger trouble !!!! Have managed to get on equaliser mode, when sharted was on 15.8V and 13,2 Amps, the hand book says it will stay on this mode for 4 hours! the smartgauge has a warning code E 03! Now 15.8 and 6.00 Fans going like the clappers!
  16. Thanks Nick I will do that, ""Watch this space". Have just tried Equalisation and it only seems to go on for about 30 seconds, then reverts back to float, is this correct?? Have tried 3 times with the same result!
  17. Hi Nick As the Amps have already gone down to 2,5 at 15volts, does this tell us that the batteries really are Fully charged? In other words they are as good as when i purchased them?? or do we mean fully charged but only 75% of what i use to have? You know the story! so do i do an equalise charge or not? I really don't know how at the moment! Thanks
  18. Just switched charger off//on. volts went to 15,0 and Amps 7,2. Amps have now gone down to 2,5
  19. Hi Boredrider I have just checked the charger and the readings now are 13.8v and 0,3 Amps it ha battery type selection, i have gone with "Flooded/open lead acid" i can not see iffloat voltage can be altered!
  20. Just a quick up date on initial problem. I have replaced my Pro Digital battery charger with a Sterling 30A Pro Charge Ultra . My reasoning is the 15.5v Equalisation mode! I have had this charger on for about 3 days, On Float i have readings on charger of 13.8v and 2.1Amps could anyone tell me what the Amps is telling me? I am still not sure whether to send the batteries back for Battery mega store to check out!
  21. Hi I don't have anybody who could help me, You say about getting a large one and replacing my Sterling.(Bearing in mind the sterling is 10 years old!) If i went down that route which ctek charger would you recommend? Would this be simple to wire in? Another idea! Tell me if i am talking rubbish! but what about this idea to de sulphate my batteries every month or so! If i bought a MXS 25 and just clipped it to my Trojan battery bank , Having turned my Sterling battery charger off! Leaving MX25 on till it had de sulphated my batteries at 15.5 Volts. then disconnect , returning to sterling charger? To me this would save rewiring and messing about in engine room. At the end of the day, which would you consider to be the best way forward? Thank You
  22. Thanks everyone for all your help! I am learning!!!! Keeping up Thanks for those SG readings, According to Trojans you can not have readings that high! Goes to prove that you can not trust the people who manufacture the things. Nick I thought my prayers may have been answered with the mention of the C Tek battery charger, but i think i can see your reasons why not! I think that the Bench power supply would be too technical for me to confidently use ! I don't think i will be in touch with Trojan again!
  23. Hi Nick I took the 12.40 reading from smart gauge, this is connected directly to the batteries. You say about a bench power supply etc! and Equalisation. This goes right over my head!!! Is it possible to buy a battery charger that will do these things for me? i would be more at ease with that! If so could you recommend one? Thanks for your time. The lights were still on when taking voltage.
