GUMPY
PatronDonate to Canal World
Everything posted by GUMPY
  2. I have done the opposite and just use the stat to control the house temperature. 17deg overnight 18deg daytime and 19deg evening. I also turned down the flow temperature from 75 to 55, so I don't get overshoot peaks. Result is house is just as warm and I've managed a 25% saving on my monthly gas bill. This is all to see how suitable my system will be for an ASHP Just to add the stat is in the hall which is a cold part of the house and although it's 19deg there it's 21.3deg in the sitting room.
  4. I have this vision of the water tank being full of them possibly a breeding colony, as after all it's filled from the same tap 😱 You would never know as the pump filter would stop them reaching the tap 😉
  5. Real world energy figures 3 bed detached house 2022 Electricity Import 1009kWh Export 2703kWh Gas 13228kWh 2023 Electricity Import 1051kWh Export 2624kWh Gas 12278kWh energy consumed 2022: 11534kWh 2023: 10705kWh 2024 gas consumption should be less than 2023 so far its looking that way.
  6. Hopefully those downwind of you enjoy breathing particulates😱 it's as bad as the exhaust from a diesel car.
  7. There are many London boaters that believe that they are green burning wood and living in a boat. One got particularly abusive when I pointed out that burning wood wasn't "green" and E-coal was better for the planet. Accused me of destroying the planet by living in a house 😱
  9. Connect nothing apart from the shunt to the battery, smartgauge excepted. This is how Loddon was wired with two alternators and two ammeters with shunts. The shunts were big enough to deal with the Beta starter motor, 300a 12V NEW 2_1.pdf
  11. I remember the day that Waterways Ian and others were commissioning Sentinel's engine down in Berko. You could almost surf on the wash and they weren't even moving 🤔
  12. Fourth company in 4 years .mmmmm🤔
  13. Scancom are primarily a business supplier who have recently started courting other users such as the charitable sector and mobile home users. I trust that explanation wasn't for me, I know full well how they operate. Maybe not 😱 https://find-and-update.company-information.service.gov.uk/company/10559377
  14. Email to Scancom customer services. Quick reply and sorts stuff quickly. Only downside is there is no way I found to check your remaining data, not that I have got near my data limit. I have the counter on the router set to reset every month so can reference that I've used 109gb in the last 10 days For £14 a month savings over Three I can put up with that 😉
  15. I think there are a few on here that can't understand how the Scancom business model works 🤔
  16. Are you sure? Why then does it sell Sims from all networks and even an all network SIM ?
  17. Scancom.co.uk But cheaper from them through Amazon
  18. Changed to Scancom at home just swapped the 3 sim out and put the Scancom one in. Changed to Scancom in the caravan just swapped the Smarty sim out and put the Scancom one in. Both worked straight out if the box no difference in speeds in the same location. Actually they sell Sims from all 4. They are not a network provider they just retail sims from the main providers.
  19. We run a Freesat box at home mainly for the record function (you don't generally get movies repeated on catch-up). There is also a terrestrial tuner and a Sat tuner in the TV which are rarely used. On top of that we have various streaming services. Did I mention I like redundancy 😎
  20. Not bad, I've read worse. https://www.theguardian.com/travel/2024/feb/17/after-five-years-on-a-narrowboat-ive-finally-reached-the-end-of-the-canal-network-lancaster-canal
  21. That's what C and I deduced. Big Kev would take money off anyone and everyone 😂 25 years ago I was still on Idleness above Lock 59, Changed boats to Parglena and then Loddon, left the mooring 5 years ago and then moved down here.
  22. What year was that? Must have been after 2002 because Caro is there. Possibly the last time it happened.
  23. That is so depressing to read, Bulbourne open days were so much fun and the pub was excellent. I'm glad we moved on and away.
