Help with cruise alternatives please
Rivelin
For the Middle Levels, you might want
  • a Yale key to give access to the facilities at March, and enable you to operate the lock at Ashline (there is an alternative ie to climb over a 3' high fence)
  • A special windlass (confusingly called an Ouse key!) to operate the slackers at that lock (what are called paddles elsewhere).
You can get both from Tina at Stanground. She will also give you one of these booklets, which are invaluable.
https://middlelevel.gov.uk/wp-content/uploads/2018/03/NavNotes18-web.pdf
Once you have wound up the slackers you can open the pointing doors, and move off and tie up at the staithe.  I hope that is clear?
