Arthur Marshall Posted April 21, 2016 Report Share Posted April 21, 2016 Minor problem but...the fuel filter on my Lister SR2 was a couple of bleed doofers on the top which you use to hoick the diesel through when it's been turned off for any reason. They are knurled things which are supposed, i think, to be only finger tight so it's quick to loosen them, but unless I give them a serious wrench with a pair of pliers they come loose and leak. The washers under them are fibre - I have a vague memory that they used to be rubber ring washers which possibly sealed better with less force - does anyone know which are best to use? Link to comment Share on other sites More sharing options...
RLWP Posted April 21, 2016 Report Share Posted April 21, 2016 They are a nuisance, aren't they. I leave them alone and slacken the inlet and outlet pipes off instead It depends what shape the hole in the top of the filter is. If the threaded hole is flat, you want a fibre washer, if it conical you want the o ring Richard Link to comment Share on other sites More sharing options...
Arthur Marshall Posted April 21, 2016 Author Report Share Posted April 21, 2016 Thanks Richard. By the way, Dave Ormerod came down and sorted out the diesel leak - replaced the leak-off and another bit. Link to comment Share on other sites More sharing options...
RLWP Posted April 21, 2016 Report Share Posted April 21, 2016 Thanks Richard. By the way, Dave Ormerod came down and sorted out the diesel leak - replaced the leak-off and another bit. He's a good bloke, Dave. Did he tell you about his workshop? Richard Link to comment Share on other sites More sharing options...
