Iain_S Posted April 8, 2016 Report Share Posted April 8, 2016 Hmm - the water in bathroom was just coming out brown (from cold tap) and flow was spluttery. Then I heard the pump whirring continuously (quieter than normal). Have cut pump off for now but could this be as simple as my water tank has run dry? Yes Link to comment Share on other sites More sharing options...
NMEA Posted April 8, 2016 Report Share Posted April 8, 2016 (edited) All pressurised water systems should have a non-return valve, either in the pump or separately. There, fixed that for you by substituting should for will, "will" certainly can not be counted on Edited April 8, 2016 by NMEA Link to comment Share on other sites More sharing options...
Zoeb Posted April 8, 2016 Author Report Share Posted April 8, 2016 I am hopeful the tank was just empty as it was noticeably echoey when I unscrewed the cap... It's filling as I type. I think I will let it overfill, reconnect the pump and open up some taps to see if anything needs flushing out (air, crud etc etc) Link to comment Share on other sites More sharing options...
Zoeb Posted April 8, 2016 Author Report Share Posted April 8, 2016 Hurrah - tank full (took hour and a half) and pump is now working as I though it should... Presumably it was just working too hard with a nearly empty tank. Thanks all... 1 Link to comment Share on other sites More sharing options...
smileypete Posted April 10, 2016 Report Share Posted April 10, 2016 Ta for the update! Link to comment Share on other sites More sharing options...
