Bee Posted April 2, 2016 Report Share Posted April 2, 2016 The Jabsco pump on our Beta 43 has developed a drip, its not from the front plate gasket where the impeller lives so I assume it is from some sort of shaft seal behind the impeller. Its awkward to get at so before I start flinging nuts and circlips all over the place has anyone had to replace theirs, if so, how did the job go? Thanks in anticipation. Link to comment Share on other sites More sharing options...
OldGoat Posted April 3, 2016 Report Share Posted April 3, 2016 By Jabsco pump - do you mean you have a heat exchanger - freshwater cooled engine? There aren't many of those around... Jabscos haven't been fitted by Beta for some time now - they fit something else. If the above is correct, then it may well be a leak through the bearings - that's what happened to mine. But first it may well be the gasket has failed. or those irritating screws on the front have come loose - they have to be quite tight. If the pump is old then the best thing is to remove it and replace the two drive bearings - quite straightforward - but you'll need a drift - I used a suitably sized socket and tapped gently to make sure the bearings go insquare. Jabsco do a repair kit. hope that helps. Link to comment Share on other sites More sharing options...
Bee Posted April 3, 2016 Author Report Share Posted April 3, 2016 Thanks, yes heat exchanger cooled, designed for hard work and a lot of river use. The engine is in the centre of the boat and the hull has frames so awkward to work in a keel cooling tank. I'll get a kit of bearings. Link to comment Share on other sites More sharing options...
