robert anthony Posted August 26, 2015 Report Share Posted August 26, 2015 Okay, so in the bedroom/rear cabin of my GRP boat it has plywood walls and pine T+G ceiling. The ceiling has a couple of discoloured pine panels due to damp but easily sorted as I've found the same pine strips at B&Q which will match with a coat of varnish. The plywood walls however are a bit smelly and rank from the rainwater leak I'm currently sorting. The plywood walls are screwed onto some hardwood battons which seem to be in good condition so I'm going to replace the plywood with some 15mm marine ply which I can get for £12.50 per 8' x 4' board. There is about a 2' gap between the GRP hull and the ply so was thinking about insulating this with expanding foam (the stuff you buy in a spray can) Is it the same kind of stuff that narrowboat builders use for insulation? Link to comment Share on other sites More sharing options...
canals are us? Posted August 26, 2015 Report Share Posted August 26, 2015 Okay, so in the bedroom/rear cabin of my GRP boat it has plywood walls and pine T+G ceiling. The ceiling has a couple of discoloured pine panels due to damp but easily sorted as I've found the same pine strips at B&Q which will match with a coat of varnish. The plywood walls however are a bit smelly and rank from the rainwater leak I'm currently sorting. The plywood walls are screwed onto some hardwood battons which seem to be in good condition so I'm going to replace the plywood with some 15mm marine ply which I can get for £12.50 per 8' x 4' board. There is about a 2' gap between the GRP hull and the ply so was thinking about insulating this with expanding foam (the stuff you buy in a spray can) Is it the same kind of stuff that narrowboat builders use for insulation? Wouldn't it take a lot of cans, depending on the area? How about using celotex/kingspan rigid insulation, then filling any gaps with the foam, cutting level then taping all the joints with the aluminium tape? James Link to comment Share on other sites More sharing options...
blackrose Posted August 27, 2015 Report Share Posted August 27, 2015 (edited) Wouldn't it take a lot of cans, depending on the area? How about using celotex/kingspan rigid insulation, then filling any gaps with the foam, cutting level then taping all the joints with the aluminium tape? James Yes, a much better and much less messy solution. Stick the kingsan or cellotex onto the grp with marineflex or stixall from Toolstation. Edited August 27, 2015 by blackrose Link to comment Share on other sites More sharing options...
robert anthony Posted August 27, 2015 Author Report Share Posted August 27, 2015 Wouldn't it take a lot of cans, depending on the area? How about using celotex/kingspan rigid insulation, then filling any gaps with the foam, cutting level then taping all the joints with the aluminium tape? James Yes, that's a much better solution, cheers Link to comment Share on other sites More sharing options...
