GSer Posted June 25, 2012 Report Share Posted June 25, 2012 Left hand side of photo, just to the left of the left hand lever above the large nut, thats the extra fuel/coldstart button. Sorry for the crap photo Link to comment Share on other sites More sharing options...
martyn 1 Posted June 25, 2012 Report Share Posted June 25, 2012 Cheers GSer that's the one Link to comment Share on other sites More sharing options...
GSer Posted June 25, 2012 Report Share Posted June 25, 2012 Cheers GSer that's the one While you're here, what is the idea and correct usage of the two levers on the injector pump, are they for testing injectors? Or for isolating a cylinder ie running the engine on one pot only? Paul Link to comment Share on other sites More sharing options...
Athy Posted June 25, 2012 Report Share Posted June 25, 2012 The two in the centre of the photo? They are priming levers (so I'm told). Link to comment Share on other sites More sharing options...
martyn 1 Posted June 25, 2012 Report Share Posted June 25, 2012 Those two levers are priming levers which are used to refill the injector lines when they have been removed etc. unlike other engines with a Gardner you don't need to undo injector pipes to bleed them. The little catches on them do also allow you to effectively turn off a cylinder but this is not advisable unless there is something wrong with that cylinder and it a get you home measure. Link to comment Share on other sites More sharing options...
GSer Posted June 25, 2012 Report Share Posted June 25, 2012 Those two levers are priming levers which are used to refill the injector lines when they have been removed etc. unlike other engines with a Gardner you don't need to undo injector pipes to bleed them. The little catches on them do also allow you to effectively turn off a cylinder but this is not advisable unless there is something wrong with that cylinder and it a get you home measure. Many thanks to the pair of you, now i know Link to comment Share on other sites More sharing options...
