Quickie Solar Question
It's t'other end I need to resolve. The best site for my panel, for me when boating single handed, is a spot on the roof 16m from the controller. So that's 16m of red and 16m of black cable. If that was 6mm cable, whassat in voltage drop for my panel? It's a 250w panel chucking out around 53v. And how terrible is that voltage drop in the bigger scheme of things!? :unsure: what am I losing battery end by having that voltage drop panel end?
I get different figures for the power loss than the ones Justme gives :help:
For 4.7 amps though 32m cable, for different cable sizes I get:
1mm2 = 12W lost
1.5mm2 = 8W lost
2mm2 = 6W lost
2.5mm2 = 4.8W lost
4mm2 = 3W lost
So I'd say go for something between 1.5mm2 and 2.5mm2 depending on cost, for example
http://www.ebay.co.uk/itm/251055879887
or if you're a bit brassic:
http://www.ebay.co.uk/itm/280721925136
If there's some unused speaker cable running down the boat, it may not be chunky enough, maybe strip a bit of plastic off and compare it to 13A mains cable which should be 1.5mm2
cheers, Pete.
~smpt~
Edited by smileypete
Just use the right solar cable.
You need the double insulation & UV protection that the right cable has.
SmileyPete, The cable calcs I used was not clear if the cable length input required was one way or total distance so that could explain some of the variation.
Either way it so small a loss just use the standard 4mm2 cable.
Think BSP plans to run it in conduit inside the boat, so buying a full 32m of solar cable isn't really needed.
Wonder if the panel hasn't got a long enough lead to reach the cabin entry point, if so a bit of solar cable or something similar wouldn't go amiss.
cheers, Pete.
~smpt~
