Wobbly Dick Posted May 3, 2006 Report Share Posted May 3, 2006 Hi, Can someone tell me, in layman's terms, what is a calorifier? Link to comment Share on other sites More sharing options...
stuart Posted May 3, 2006 Report Share Posted May 3, 2006 (edited) Hot water tank :-) Basically the same as the hotwater tank in a house, it has coils inside which take hotwater from the engine, boiler or stove and heat the cold water in the tank. Have a look at http://www.albion-online.co.uk/marinecalorifier%20x.html Edited May 3, 2006 by stuart Link to comment Share on other sites More sharing options...
DHutch Posted May 3, 2006 Report Share Posted May 3, 2006 Yeah, as stuart says, its the hot water tank. There ussaully about 50-100liters in size, say about 12" in diameter, and about 3ft in lenght. - And avalable in both Horizontal and Vertical versions. You can also get single or twin coil versions. - One coil is conecteced upto the cooling loop of the engine, and then the second one, if present, us usally conected upto the central heating loop. (power eather by a stove and back boiler, such as morso's "squral", or a gas/diesal heater) Another option is to have a small gas combi-boiler as you might in a house, or have a gas instant water heater, such as the paloma We have a twin coil calorfyer, one coil powered of steam from the boiler, and the other off the central heating loop. - Then also a paloma, with valves to switch between the two. When crusing we can use the steam (like you would you engine) to heat the water. This it most usally this we do. - When not crusing we can use the paloma. Say if where doing a day or twos work on the boat. - And if you living onboard in winter, you can use the stove, which saves the gas. (the palomas a little thirsty if you use it longterm) Daniel Link to comment Share on other sites More sharing options...
Wobbly Dick Posted May 3, 2006 Author Report Share Posted May 3, 2006 Cheers Stuart and Daniel! It's all become clear....... an indirect water heating system.... just like in the house.... got it! Link to comment Share on other sites More sharing options...
