Boat&Bikes Posted November 8, 2011 Report Share Posted November 8, 2011 I want to fit a couple of spotlights inside our boat.I have seen various threads here on useing items from ikea etc which with transformer removed can be plugged to 12v system.1st question does this just mean simply chopping the wires to remove transformer then wireing to a 12v plug? Secondly which is best,running 12 or 240v as far as battery power useage? I have both power outlets available but would prefer to use 12v sockets as they happen to be handily placed and are never used for any other devices. Cheers, Ian. Link to comment Share on other sites More sharing options...
WotEver Posted November 8, 2011 Report Share Posted November 8, 2011 Yes, and 12V in that order Tony Link to comment Share on other sites More sharing options...
Chalky Posted November 8, 2011 Report Share Posted November 8, 2011 Don't do it if they are LED lights. The transformer is a current limited power supply and you'll blow the LEDs if you connect them directly. If they are LEDs then you'll need a buck converter to run them. These are available from a number of electronic stockists and are easy to use, but you'll need to kmow the business end of a soldering iron to fit them. If they are halogen or bulb then there's not a problem. Link to comment Share on other sites More sharing options...
Phil Ambrose Posted November 8, 2011 Report Share Posted November 8, 2011 Yes, and 12V in that order Tony Agreed, and no point taking perfectly good 12v leccy and waste some by turning it into 240v (via inverter) Phil Link to comment Share on other sites More sharing options...
