WotEver Posted September 7, 2010 Report Share Posted September 7, 2010 I remember Phil talking about this once and I believe I have it right that his advice would be, once you've done what you describe with the maroon and green, to then mask off and paint the 4 cream diamonds. That way you'll have no 'step' at the edge of the paint, and you'll have a smooth surface to varnish. If you didn't already know, paint up to masked edges with a pretty dry brush for the first coat, and then heavier with the second coat. That way the first coat tends to seal the edges of the masking tape and avoid bleed. Tony Link to comment Share on other sites More sharing options...
Evo Posted September 7, 2010 Author Report Share Posted September 7, 2010 (edited) I'm not good enough with a brush...in fact I am completely useless with a brush, everytime I've used a brush its crap. So I wont be brushing anything. I use a 4" short soft bristle roller..(the type they sell for varnish in BandQ). I painted the whole boat with one last year and it came out pretty good with the right conditions. I've used that Silkens paint is it..?? cheaper than the other stuff. The 3 colours incidently are the 3 colours from the rest of the boat. I will only be applying enough paint for coverage....probably 2 very thin coats, I'm not bothered about a few thou step down for the cream, the whole lot will be varnished over anyway. Thanks for advice Tony, the lining tape I use does not allow bleeding. Its not sticky as such, its more of a vinyl and as you apply it you can see through it and see the change in shade as it 'adheres' to the surface. The rollering leaves a perfect flat smooth surface, if sometimes not as shiny as brushing, but as you can imagine perfect for a quick blast over each colour in this case. .....I hope Edited September 7, 2010 by Evo Link to comment Share on other sites More sharing options...
WotEver Posted September 7, 2010 Report Share Posted September 7, 2010 ... the lining tape I use does not allow bleeding. Its not sticky as such, its more of a vinyl and as you apply it you can see through it and see the change in shade as it 'adheres' to the surface. That sounds like interesting stuff - where does one obtain some? T Link to comment Share on other sites More sharing options...
Evo Posted September 7, 2010 Author Report Share Posted September 7, 2010 The stuff i use is on here. I dont get it from there and i dont pay that for it...thats just a quick google to explain what it is. http://www.leisureshopdirect.com/Marine/maintenance/Tapes-_Masking_Tape_film_and_paper/3M_218_Fine_Line_Masking_Tape.aspx Link to comment Share on other sites More sharing options...
WotEver Posted September 8, 2010 Report Share Posted September 8, 2010 Thanks for the info - looks good Link to comment Share on other sites More sharing options...
Evo Posted September 8, 2010 Author Report Share Posted September 8, 2010 This is the actual tape I use, not sure if they still do this stuff as I've had it years from car/bike spraying days. Last night I bought some off Ebay though...search for "fine line tape" or "fineline tape" Link to comment Share on other sites More sharing options...
Evo Posted September 9, 2010 Author Report Share Posted September 9, 2010 (edited) The painting - first coat of red and green....just second coat, pull lining tape, and varnish now. well chuffed with it so far, finish is excellent (better than in pic). ediyed to add final pic of paint...debating wether to varnish or not,,,its so shiny i cant get a decent pic in the kitchen at night, flash keeps going off and making the finish look blotchy speckly and basically crap, its not, its actually quite impressive The colours are funny looking too, but you get the idea. Edited September 9, 2010 by Evo Link to comment Share on other sites More sharing options...
