colin loach Posted August 23, 2010 Report Share Posted August 23, 2010 Hi all. I have just installed a pressurised central heating system working from the second coil of the calorifier. I have installed an accumulator but not sure what pressure it should be set at. The system is pressurised to one bar. Colin. Link to comment Share on other sites More sharing options...
Tony Brooks Posted August 23, 2010 Report Share Posted August 23, 2010 Hi all.I have just installed a pressurised central heating system working from the second coil of the calorifier. I have installed an accumulator but not sure what pressure it should be set at. The system is pressurised to one bar. Colin. If it's a central heating system it is not an accumulator - its an expansion vessel so it needs pressurising with NO pressure in the system to about 1 bar. I just hope this central heating system is not a stove and that it has both a normal thermostats and an overheat thermostat on it as well as decent safety valve venting to the outside - otherwise, eventually - BANG Link to comment Share on other sites More sharing options...
colin loach Posted August 23, 2010 Author Report Share Posted August 23, 2010 If it's a central heating system it is not an accumulator - its an expansion vessel so it needs pressurising with NO pressure in the system to about 1 bar. I just hope this central heating system is not a stove and that it has both a normal thermostats and an overheat thermostat on it as well as decent safety valve venting to the outside - otherwise, eventually - BANG The central heating works from the second coil of the calorifier which is heated by the water in the calorifier, which is heated by the engine. The calorifier has a prv fitted so the heating cant get hotter than the hot water system that feeds the taps Link to comment Share on other sites More sharing options...
