Dutch Posted July 16, 2009 Report Share Posted July 16, 2009 (edited) Today i was messing with the coax tv cable and noticed when i was holding both coaxial plugs i got a mild shock so i got out the metre and tested the current and got a reading of around 100 volts.I have one tv arial into a splitter to two Tvs what tests can i conduct to find out where this voltage is coming from.I am on shoreline 240v also have an inverter which is switched off i checked between one coax plug and the case on the digi box. Mick Edited July 16, 2009 by Dutch Link to comment Share on other sites More sharing options...
WotEver Posted July 16, 2009 Report Share Posted July 16, 2009 Today i was messing with the coax tv cable and noticed when i was holding both coaxial plugs i got a mild shock so i got out the metre and tested the current and got a reading of around 100 volts.I have one tv arial into a splitter to two Tvs what tests can i conduct to find out where this voltage is coming from.I am on shoreline 240v also have an inverter which is switched off i checked between one coax plug and the case on the digi box.Mick Hi Dutch, I've many times seen TVs with volts on the aerial socket. Particularly cheap TVs and even more often when Live and Neutral are incorrectly wired. Never enough current to harm, but disconcerting nonetheless. To find out where it's coming from is just a process of elimination, so let's start with the most likely. Firstly you need a good known earth from which to take the measurements. You can either connect a wire to the earth pin of a 13A plugtop, or you could run a wire from your common earthing point where it's bonded to the hull, or you could use the metal case of some piece of electrical apparatus. Whatever you use, connect one side of your multimeter to the earth and then touch the other lead to the aerial socket on your TV. If that's not reading, then try checking the aerial plug... etc, etc until you find the one piece of equipment that's leaking. Hope that all makes sense, Tony Link to comment Share on other sites More sharing options...
Dutch Posted July 16, 2009 Author Report Share Posted July 16, 2009 Hi Dutch, I've many times seen TVs with volts on the aerial socket. Particularly cheap TVs and even more often when Live and Neutral are incorrectly wired. Never enough current to harm, but disconcerting nonetheless. To find out where it's coming from is just a process of elimination, so let's start with the most likely. Firstly you need a good known earth from which to take the measurements. You can either connect a wire to the earth pin of a 13A plugtop, or you could run a wire from your common earthing point where it's bonded to the hull, or you could use the metal case of some piece of electrical apparatus. Whatever you use, connect one side of your multimeter to the earth and then touch the other lead to the aerial socket on your TV. If that's not reading, then try checking the aerial plug... etc, etc until you find the one piece of equipment that's leaking. Hope that all makes sense, Tony I will try that in the morning,if or when i trace the source what can i do to cure it? Mick Link to comment Share on other sites More sharing options...
bramley Posted July 16, 2009 Report Share Posted July 16, 2009 i always remember on a old philips tv holding the tv arieal, trying to find the tv socket for it, and feeling my hands get a small consitant shock... no idea why, always put it down to passing currents Link to comment Share on other sites More sharing options...
twocvbloke Posted July 16, 2009 Report Share Posted July 16, 2009 Had the same experience myself with many TVs, I think it's down to modern TVs not being earthed, being Double Insulated, so any voltage that develops on the internal ground just hangs about waiting for you to, ahem, finger the socket and get a shock.... It's annoying, but, it's not life threatening, well, I don't think it is, maybe for those with pacemakers and personal defib things... Link to comment Share on other sites More sharing options...
WotEver Posted July 17, 2009 Report Share Posted July 17, 2009 I will try that in the morning,if or when i trace the source what can i do to cure it?Mick Let us know what you find and we'll see what we can suggest T. Link to comment Share on other sites More sharing options...
Chris J W Posted July 17, 2009 Report Share Posted July 17, 2009 Couldn't it also be the TV supplying the power for an amplified aerial? Link to comment Share on other sites More sharing options...
Dutch Posted July 17, 2009 Author Report Share Posted July 17, 2009 Couldn't it also be the TV supplying the power for an amplified aerial? No Chris i have not got amplified arial Mick Link to comment Share on other sites More sharing options...
Chris J W Posted July 17, 2009 Report Share Posted July 17, 2009 No Chris i have not got amplified arialMick The TV could still be supplying power even if it's not being used. For instance, my HUMAX Freeview PVR has the aerial power on by default. Link to comment Share on other sites More sharing options...
Dutch Posted July 17, 2009 Author Report Share Posted July 17, 2009 The TV could still be supplying power even if it's not being used. For instance, my HUMAX Freeview PVR has the aerial power on by default. Strange thing is i can not now get a reading as i did last night??When i went to plug the coax plug into the arial socket i got a mild spark Mick Link to comment Share on other sites More sharing options...
WotEver Posted July 17, 2009 Report Share Posted July 17, 2009 Strange thing is i can not now get a reading as i did last night??When i went to plug the coax plug into the arial socket i got a mild sparkMick That's common, too. Keep the mulimeter and earth wire handy, so the next time it happens you can confirm exactly where it originates. It might also only happen when the TV is warm or when it's cold.... T my HUMAX Freeview PVR has the aerial power on by default. Think you'll find that's around 12V, not 100V. Link to comment Share on other sites More sharing options...
Chris J W Posted July 17, 2009 Report Share Posted July 17, 2009 Think you'll find that's around 12V, not 100V. Ah-hem. Yes, I'd utterly misread the OP as 10V ... really must get some new reading glasses! Link to comment Share on other sites More sharing options...
ChrisPy Posted July 17, 2009 Report Share Posted July 17, 2009 I had to fiddle around with the aerial socket in an old TV to try to get a better connection. I forgot that the TV chassis is live. The aerial socket came into contact with the chassis and I got a shock. Link to comment Share on other sites More sharing options...
Yoda Posted July 17, 2009 Report Share Posted July 17, 2009 Normally the gain on antennas is log 10 dB but the voltage gain is log 20 dB, so this might have something to do with the cable voltage. Link to comment Share on other sites More sharing options...
Semitrad Posted July 17, 2009 Report Share Posted July 17, 2009 many modern flatscreen sets run from 12v which is derived from the mains via an isolated powerunit, they are very safe and you are very unlikely to get a shock from these. The previous generation with CRTs were "double insulated" the mains supply connected to an onboard power supply and was never connected to the chassis, often isolated from it via a transformer, with controlling feedback using an opto-isolator. Before that, the mains was connected directly to one side of the chassis and the ae socket had it's own isolating components incorporated, these could fail, leaving the socket live and possibly the antenna as well, not good news for the unwary aeriel installer on his ladder! In practice this rarely happened as the antenna is usually a short circuit to 50Hz (Almost said cycles) and all that happened was an almighty bang as the fuses blew. Very hard to say where the leakage is from, bear in mind that if you were to sit on a power cable as the birds are able to do with impunity, you would be quite safe until you touch the ground. Link to comment Share on other sites More sharing options...
WotEver Posted July 17, 2009 Report Share Posted July 17, 2009 50Hz (Almost said cycles) You should have done. It would have looked cute and made me feel all nostalgic Link to comment Share on other sites More sharing options...
