Steve 130 Posted March 26, 2008 Report Share Posted March 26, 2008 Hi folks, am in the process of fitting a back boiler to our stove and want to know If I need to fit a Pressure relief valve at all in the system. The system will feed three radiators down the length of the boat and also a coil through the calorifier with a standard header tank. The system will be pumped and this will be switched with a pipe stat to make sure we do not boil the water in the pipes but I am not sure if I need to fit a PRV on the top outlet of the boiler. Any help much appreciated. Link to comment Share on other sites More sharing options...
steelaway Posted March 26, 2008 Report Share Posted March 26, 2008 Hi folks, am in the process of fitting a back boiler to our stove and want to know If I need to fit a Pressure relief valve at all in the system. The system will feed three radiators down the length of the boat and also a coil through the calorifier with a standard header tank. The system will be pumped and this will be switched with a pipe stat to make sure we do not boil the water in the pipes but I am not sure if I need to fit a PRV on the top outlet of the boiler. Any help much appreciated. Hi I am not a plumber but if you have a header tank any high pressure will force it way out the breather in the top of the tank. Alex Link to comment Share on other sites More sharing options...
denboy Posted March 26, 2008 Report Share Posted March 26, 2008 as a general rule prvs are fitted to the top of the clarifier Link to comment Share on other sites More sharing options...
