matty40s Posted January 17 Report Share Posted January 17 10 hours ago, BWM said: There are a few boatyards that use an oversized barge as a dry dock. With a door or stop planks at one end, the barge is sunk to allow the boat to be worked on to enter it, the door/stop planks are replaced, water pumped out and you then have a floating dry dock with a boat inside. This may be a realistic option if space allows. Someone (an occasional forum contributor and decent boat painter) did try to bring a widebeam size dry dock from somewhere on the Nene to the GU, and tow it along and work from it. I recall CRT put a stop to it as it was too large to fit through locks, therefore would not have been able to fulfil the range required by the 'boat without home mooring' licence. Link to comment Share on other sites More sharing options...
Drayke Posted January 20 Report Share Posted January 20 On 17/01/2024 at 12:43, BWM said: There's at least one on a narrow canal, Brinklow boat services use one. As do the Boatyard on the K&A at Hilperton. Link to comment Share on other sites More sharing options...
