mayalld Posted June 14, 2021 Report Posted June 14, 2021 Daughter's BMC 1.5 suffered a leak on the final leg of the spill rail (final injector back to fuel filter), which has been given a temporary fix, but it won't pass a Boat Safety. Apparently, rather than trying to replace and crimp a new pipe, the best option is to buy a new spill rail. However, the only one that comes up on Google; https://rimmerbros.com/Item--i-ERR1259P--SelectedCurrency-1?gclid=CjwKCAjw_JuGBhBkEiwA1xmbRUPQo5c6xgcxBU9MrkhA_o9OU3tZxofCVIFu2b2ASTEuHEJ1t1QwkBoCsHEQAvD_BwE I suspect isn't compliant. Can anybody point me at a source of a spill rail that will comply? Thanks
Tony Brooks Posted June 14, 2021 Report Posted June 14, 2021 I am sure Calcutt can supply metal ones. I found some marinations have a too thin fuel filter bracket so it waves about and fractures the pipe where your daughters has. You can minimise it by pushing a pieced of wood between hand and bracket. Personally, I would get hold of a bit of copper pipe and silver solder it over the break. Not ordinary solder because that is a BSS fail.
