Hello everyone. I have a home mooring on the Leeds Liverpool in West Lancashire. My SR2 developed an oil leak around the cylinder head joint where the rods, pipes etc run so I took a look,
On disassembly I noticed one of the injectors seemed to be carbonised much more than the other. There has been recently a slight degradation in the starting (used to be first or second turn) and a bit more smoke (not black or blue smoke, something in between). The engine oil (Morris) looks and smells ok (aware of the fuel leakage issues on this engine). I would really appreciate if there is someone recommended in the area who is prepared to spend a bit of time with me (suitably remunerated) just to go over things and take a look to see if everything is in order and help to reassemble as I don't have a torque wrench.
Go say Hi to the Mersey Motor Boat Club at either Red Lion bridge  or Lydiate  and I am sure they will be able to give you a steer.
N
