Skip to content
nicknorman
Everything posted by nicknorman
  1. And there was me thinking you might be interested in some feedback. I am so stupid! I should have realised it’s transmit only.
  2. Yea it’s not too bad. I think the requirement for separate “installer” and “user” login privileges is a bit far fetched. Yes you do get that with eg domestic solar/battery systems, but as far as I know the current crop of tech designed for boats doesn’t have that capability. There is no point in proposing a standard if none (or virtually none) of the current tech supports it. Also the thing about ventilation is pretty vague. Obviously we know why it’s there, but it is fairly meaningless without specifying what the ventilation has to achieve. If looking to cater for the major cell rupture scenario à la ABC boat then the vent has to be pretty big and close coupled to the battery compartment. On the other hand it might be better to prioritise not getting into that situation in the first place! In our case the Li batteries are in the engine bay which is under boards within a trad stern. And the engine bay is vented to outside through some hooded vents on the rear bulkhead. But of course the same vented space runs under the cabin as bilge to some other vents at the front. So we meet the requirement (batteries not in a domestic space and vented to outside) but if there was to be a cell rupture, the rate of release of gas would probably overpower the vents and the gas would leak into the residential space. So a compliance with the letter but failing to meet the objective. Also our BMS doesn’t limit max current, but there is a 500A fuse very close to the battery. And then there is the different battery chemistries - “should remain electrically separated”. So it’s not OK to have LA battery negative connected to Li battery negative? I don’t think that is what was meant, but it’s what is said. Also very verbose (designed by committee, where words are added to satisfy each committee member’s bonnet bees). Needs to reduce the word count to about 50%!
  3. Completely different meanings of the word “equalise”.
  4. If you understood that it’s not a river lock…
  5. LifePO4 cells can be used for cranking too, what normally precludes this on a leisure Li battery is the limited current capability of the BMS.
  6. That’s correct, although of course the heaters use up some energy. The sodium battery data sheet says it can charge up to 60% SoC below -10c. I wonder if they actually mean that (hard to obey since one doesn’t necessarily know the SoC accurately) or whether they mean charge at 0.6C. Anyway with the stabilising effect of canal water I can’t see it giving any significant advantage over LiFePO4
  7. One problem is the wide range of voltage between full and empty. Which of course is good for the trivial issue of estimating SoC, but bad for basic devices (without constant power circuitry) that will struggle to operate adequately over the wide voltage range. As with Li, if the entire system is designed from the outset for Na-ion then no problem, but it you are going to plonk a Na-ion battery into a system designed for LA, it is going to be problematic, and more so than for Li.
  8. However it would be easy to be taken in by Sterling's words, which talk about "going to float" or somesuch, but when you read the very small print it says that this is assuming the alternator has a very low basic regulating voltage such as 13.8v, which no vaguely modern alternator does have.
  9. “Proper” regulators such as the Wakespeed, Zeus or Mastervolt Alpha are replacement regulators, ie the original regulator is removed or at least isolated, But “supplemental” regulators (boosters) such as the Adverc or Sterling act in parallel with the existing regulator such that they can only increase field current and hence output, they can’t decrease it below what the original regulator is doing.
  10. No the adverc can't decrease the voltage, only increase it. What makes you think that your batteries want/need 14.2v? It seems quite low. Unless they are Li?
  11. The only bit I didn’t like was his “quandary” between boaters wanting early notification of closures, vs hire companies who want to keep it quiet. Seems a no-brainer to go with the former, since the latter want to deceive their customers by withholding information (if what he says is universally true, which i doubt).
  12. I heard (could be false rumour) that CRT have not been running the backpumps at Napton, Calcut etc at all this year to save money on electricity.
  13. You get a prize for having very long arms?
  14. Yes I suppose that fits. But it also smacks of disingenuousness.
  15. Yes, we would just have to cut the cabin top off but that is no problem... It's interesting that they have left Tipton locks operable whilst stopping moving up to the Wolverhampton level by any other means (Smethwick, Spon Lane, Brades). Not sure what the logic behind that is.
  16. But why give only 1/2 day’s notice? Why not open it for a day on Wednesday which would give enough time for people to get where they need to be. Yes we will be exiting via the Stourbridge. Hopefully!
  17. Obviously we could do it if desperate, but we don’t want to go that way and don’t particularly like night stopping at Wolverhampton top lock. If we did want to do it we are not yet back on the boat having decided we might as well have an outing day. But anyway it is not supposed to be an endurance sport and it is supposed to be a relaxing leisure activity. My point is that it was unnecessary to offer such short notice. Smacks of making it up as you go and no proper plan
  18. Which is not a great deal of use for those in central Birmingham- posted at 13:00 and it’s 6 hrs to Wolverhampton top lock even if you were in a position to depart right away.
  19. We arrived in central Brum this afternoon. Loads of space, only 1/2 full. We were planning to exit via B&F but apparently there is a lock that was perfect yesterday and definitely didn’t need any preventative maintenance, which today is totally …#f-word#ed. Must have been the vandals. Or the goths. Or the aliens. Or global warming.
  20. Aka bad tempered glass.
  21. No, because you are allowed to walk off the boat and travel in any direction you choose. Anyway the “lawful authority” bit comes in and CRT have lawful authority to temporarily close canal for water resource reasons.
  22. Presumably it was the large pole who actually freed you. They breed ‘em tough in Eastern Europe.
  23. Should have gone to specsavers.
  24. Complaints that the branch was closed for 30 mins are inconsequential because a bank can choose when and for how long to open. Whereas a complaint that the bank has acted unlawfully is (or should be) a much more serious matter. Regarding the 30 minute customer they could be personally told that the doors were going to be locked for 5 minutes and they could choose to leave now or in 5 minutes. No need for a tannoy announcement.
  25. Regarding the warning, a bank robber would have to be hanging about in the branch for an awful long time to be lucky enough to to encounter one of these security lock-ins. And if the lockin has any value, then it wouldn’t matter that a robber was tipped off because … there is a lock in. So the argument fails reasonable analysis. Not that I think it would be a good way to deal with the situation. A much better way would simply to stop new people entering the branch and then when the last customer exited, lock the doors and do the moving thing.
Account
Navigation
Search
Search
Chrome (Android)
  3. Adjust your preference.
Chrome (Desktop)
  2. Select Site settings.
