I recently discovered some mould in the back of a cupboard - it's against the lining of the cabin about a couple of inches above the floor - behind the lining is a gap between the edge of the floor and the spray-foam insulation. I think the cold air in the bilge is causing condensation to form in this area, leading to the mould.
So, I have some questions...is this gap to allow ventilation to the bilge - what would happen if I closed this gap with more spray foam? - just the area behind the lining of the cupboard - bear in mind the other side of the barge would still have the opening. Would it be better to have vents in the cupboard panels to draft more air through this area? Or both? It's easy to remove and attach the cupboard and lining for access.
The other thought I had was in how the bilges are constructed - reinforcing cross-members span the bottom plate - channels are cut to allow water flow to the rear of the vessel - for water...but the top of the cross member is used as a platform to support a batten that supports the floor - the battens, as far as I can ascertain are not notched to allow air to circulated - so each reinforced "cell" between the supports does not have good air-flow barring the side sections, which as I have mentioned allow the cold air to cause mould on the cabin lining inside the cupboard...
What about sealing the entire interior floor section - airtight, then dropping in Argon gas to prevent mould and as an anti-rust? I imagine it would be simple enough to fit a membrane under the floor, with a gas valve to introduce the Argon? Because Argon is heavier than air, it should stay there and topping up would be a simple affair, when needed? Any thoughts?
