all of the following is in IMHO.........
Tony
my answer was written to a wider audience than engineers alone, a gate valve (if you read the post that is what i was talking about) is rotary to the layman in that you rotate a handle to actuate even though this is then transfered via a thread to a perpendicular to flow linear motion of the tapered gate or disc. Most valve seizing occurs at the thread not the internals except where as with a gate valve when it is closed the faces of the disc and the valve body can seize together
Quite right they can be different colours on the top! but i think you will find red is by far the most common, maybe we should poll the forum on knob colour
Chris W
as for precipitation of Calcium salts (not Calcium) unusually these are inversely soluble (more heat less soluble) and can in certain situations precipitate at temperatures below 80degC, in the bulk water and is more likely to need a "key" to start it such as a heated surface, this as I said is less likely to be the coils and more likely the imersion heater elements which can be easily 100degC+
Peter F
good point and not one I had considered, if it weeps and precipitation forms on the seat/trim then it could continually weep and may benefit from a blast to break it up
my mind on this works a little differently in that in the real world of pressure relief or safety valves the last thing you want is them weeping, indeed where I'm working right know if a valve has actuated and passed water it has to be re-calibrated, if these boat valves have been fitted to weep due to expansion its more an unloader than a PRV (or PSV)
this is why I fitted two accumulators to my system which is plumbed with no check valve between the hot and cold so that pump pulsations are taken by the lower set accumulator and then heat expansion is taken by the upper set one through the whole system
In conclusion (but I'm still not 100% in my own mind about this) if you have an accumulator on the hot this is good for the valve and will mean it should never lift and as the mechanism is dry and the seal is elastomeric to metal should never seize, if you don't have an accumulator and the valve weeps then blast it, or fit an accumulator
oh by the way you will probably find if you have a fairly modern boiler at home it has the same kind of valve fitted and my Baxi makes no mention of blasting it!!!!
