as this thread is similar to what I am researching at the moment because of the boat I'm watching has an air cooled lister and without starting a new one off, I have seen some of the things the americans are doing with twin use solar panels.
solar panels get hot, they can;t help it and when hot they lose efficiency, I was surprised to see our house panels lost around 40% of their capability during the super hot spells we had during the past few summers, cooling them down keeps them efficient. our panels were also designed for low UV climates so they gathered more energy from winter light.
so how to cool them down - basically put a water pipe behind the panel and then a back on that with a circulation pump into the cauliflower. the yanks have done it with silicone pipe, hope pipe, plastic pipe, aluminium and copper pipe. I haven't tried it out but intend to, there are also some dome shaped collectors that use standard black corrugate cable trunking so I assume it copes with the temperatures well enough. in theory it doesn't need a pump either as it should thermal siphon into the cauliflower. the only weak point I see is like when I plumbed in the wetback boiler at home - you probably need a heat sink somewhere or something to stop it blowing if left unchecked..
If I was going to moor south facing or leave the boat empty for a while I would even consider a DIY solar air heater i've seen made from beer cans.,
