thanks I have now worked out what is what's you are right it is not complicated Thanks for all the help I now know how it works. these forums are the best
Cheers Neil
Hi got a navicom RT 160 marine radio but no user's manual can any one help with one all the one's on the Internet are in French I can't find one in English thanks
thanks do you have a good diagram of the gear box As the one in the manual is not a exploded one if not when I start to rebuild I will have a lot of questions it's mostly the spacers and washers that I am not to sure about . Neil
Hi here are some pics of my gear box after I striped it for a rebuild not to bad will need both bearings and seals and a good clean But had a bit of a desaster had all the bits set out on a table in the order they were taken apart the table got knocked over I think I can work out where most bits go but could do with a exploded diagram of the gear box as the one in the manual is not that good can any a one help
Got my gear box ready to lift out hope to get it out next weekend will post pics of the rebuilding of it hopefully it won't be to bad I will know what gaskets and seals I will need when I get it striped
Neil
I don't know all I know is the boat has not been on the water for 3 years the reduction box oil is clean all so the automatic float switch was not turning the bilge pump on so the gear box could have been under water
thanks for the reply boat has not been on the water for 3 years no leaks from the box so I think the boat has been full of water at some time and the water has got past the dip stick looks like I will have to get the box out and strip it down
Hi that checked the oil in the hydraulic gear box see pic . engine runs when gear liver is in the ahead position but stops dead when I put it in to reverse . checked oil and found what's in the pic this was nearly up to the top of the dip stick any one got any ideas as I can not afford a reconditioned one . I will put fresh oil in the box and try it again this is not all the oil that came out
so I don't need shims thanks Richard for your help still want to fit electric oil pressure sender can you mark where to fit it on the photo I put on a previous post for me all so is there a diagram of the piping for the water pipes
thanks Richard the shaft on my one is stainless steel with two bearings and two water seals all the bearings are held in by a cerclipe will this make a difference or will I still need the spacers cheers Neil
