thanks I have now worked out what is what's you are right it is not complicated Thanks for all the help I now know how it works. these forums are the best
Cheers Neil
Hi got a navicom RT 160 marine radio but no user's manual can any one help with one all the one's on the Internet are in French I can't find one in English thanks
thanks do you have a good diagram of the gear box As the one in the manual is not a exploded one if not when I start to rebuild I will have a lot of questions it's mostly the spacers and washers that I am not to sure about . Neil
Hi here are some pics of my gear box after I striped it for a rebuild not to bad will need both bearings and seals and a good clean But had a bit of a desaster had all the bits set out on a table in the order they were taken apart the table got knocked over I think I can work out where most bits go but could do with a exploded diagram of the gear box as the one in the manual is not that good can any a one help
Got my gear box ready to lift out hope to get it out next weekend will post pics of the rebuilding of it hopefully it won't be to bad I will know what gaskets and seals I will need when I get it striped
Neil
