Content Count
131 -
Community Reputation
11 NeutralAbout PeterCr
- Birthday 09/09/1956
Gender
Location
Australia
Previous Fields
Boat Name
Endeavour
690 profile views
So the interval is 200 hours and I'm currently to about 235, hence the question. I'd prefer not to leave it to do an oil change nearer layup time but change oil now, though the engine does get 3 to 6 hours use each day, not short runs. I use the oil recommended by the engine company. Like Roland I don't use the boat over winter and it sits for 7 months. So perhaps I should be doing one oil change now and one for winter.
PeterCr started following Red diesel petition, Oil change for winter, Go Kart and Wheel Barrow wheels as mooring fenders and and 1 other
My engine is currently due for it's oil change etc. Well it's overdue really. I'll be back at my marina to lay the boat up for the winter in about 40 or 50 hours. I know I should change my oil before the winter, however I'm wondering if I should still be changing the oil for winter if it's only 40 or 50 hours old as I've already changed it now.
We have wheelbarrow wheels, they work fine except that from time to time they flip up on their side so obviously reduce their effectiveness. You see them in some chandleries for extortionate prices, we got them off ebay for about 6 pounds, they're fine.
Thinking about a bent propeller. I had thought that if I had a very slightly bent prop shaft it might take some weeks for it to wear out something in the stern gland, and therefore a while before any noise began. But if the prop was bent then I'd assume the noise would have started straight away, not some weeks later. I might see about that when I'm back to my marina. I'd still like to find out what this reverberating noise is.
A bent propeller shouldn't be as much of an issue as a bent prop shaft I would think. We've been motoring along as normal so there's no problem I can see other than the noise, which is only annoying in so far as I don't know if it's serious or not. So if there's no obvious problem then a small bend in the propeller, which I haven't noticed when feeling around, should be ok hopefully.
I put the lump hammer on the bottom with the handle to within a mm or so of the shaft and did a full rotation. I don't see any movement. I tried it in a couple of different places. So that's though I'm still mystified about the reverberating noise. I had wondered about that exact same thing and moved the plate around a bit for that reason. Glad you found that as I suspect now that's what it is.
Good idea Tony, thanks. Yes the engine mounts are ok. Also the prop is fine thanks Rusty, I've looked at that. I did expect a bend in the prop when I hit the wood but it's fine.
2 or 3 weeks ago I started hearing a reverberating noise when motoring. It seemed to me to be about the same frequency as I would expect the prop to be turning, and increased with revs. Nothing in neutral. Not loud but definitely there. I'm wondering if I have a bent propeller shaft. About 3 or 4 weeks before that I hit a nasty piece of wood, though the noise seems to be more recent. I don't feel anything through my feet and not really through the tiller, though on rare occasions I do think there's something through the tiller, but may be imagining it. I have also had another strange noise, though rarely. Every now and then I get a clattering noise in reverse, nothing in forward. Most of the time it's perfectly normal in reverse. I have a vetus water lubricated stern gland/propeller shaft. If it's bent then it's certainly only minor. Any ideas how I could determine if it's the propeller shaft? Or what else it could be? Cheers
Passed yesterday, the duck/ducks are still in the cage, I only noticed one but there was something over the cage. Also I think a couple of chickens. No sign of the boater that we noticed. They did have food in a dish in the cage and a canny moorhen had it's head through the bars eating the food.
Can't sign it, I'm not a citizen or resident. But I'm still a boater. 😞
Not quite so clear, further up the canal the weed is quite a problem, going through Blackburn I was down the weed hatch 10 times before giving up and accepting that our forward motion would be slow. Several boaters complained to us about the weed they encountered. We went up the L&L a couple of weeks ago and had no problems with weed, but it was quite an issue coming back.
We were in the middle of the flight when the lockie got a phone call from CRT telling him the restrictions were lifted. They decided to lock it anyway at the usual time for that day as they had no lockies organised for the afternoon, but then it was to be unrestricted from the next day he said. For us the main annoyance in the flight was the weed at the top lock. I cleared the prop when on the landing and got so much weed on the prop in 50 yards that I lost all forward movement and had to pull the boat in. The duck weed was so thick on one overflow that the water level of the pound was high and 2 boats in front of us had some real problems with water coming over the top of the gates onto their deck. The lockie was quite worried till they got it sorted.
We moored in the pound above the dry dock a couple of weeks ago, no problems. We did look at the pontoon but didn't like the look of it.
Hows The Grass Where You Are ? ( Non Herbal )
PeterCr replied to Parahandy's topic in General Boating
We've had a problem with too much mowing. On the L&L last week, in a lock with another boat going up. A van turns up and out pile 2 young blokes, one pulls out a huge mower and the other a strimmer. Bloke with mower starts towards us mowing and gets closer till he gets right to the edge of the lock approaching our boats while we are waiting for the gates to be opened. 5 people standing around the top gates. I asked him to stop mowing till we exited the lock, the reply was "don't worry about it" and he kept on mowing. Both guys wearing safety equipment, the people at the gates and on the boat no safety equipment, mower a few feet away. On the landing of the next lock while waiting on the landing I stood right beside the back of the boat so he couldn't mow right alongside the boat without running me over. So he moved to the other side of the path and kept going, throwing 2 stones into my paintwork. Probably the same for the second boat ahead of me. In the lock again he mows almost on the side of the boat next to me. Maximum of 2 feet away, again no one with any safety equipment. The strimmer bloke did stop but only once asked. I put in a complaint to the local office, in their reply they tell me they are getting onto their contractors about it. I did point out the likelihood of significant legal action if someone had, for example, lost an eye to a stone or some other calamity happened. -
Just had a boat come up past us so all should be good now.
