Ok this is going to take some writing out, please bear with me.
The boat has a sterling power pro plus 600w inverter, a sterling 5kva 230v alternator/generator (this is essentially a generator the runs off the main engine via a bloody big alternator) and it originally had two sterling 40amp 3 stage battery chargers. It also has two solar panels 1x140w &1x80w that were until I changed it running through a little pwm controller, the controller is now a 40am tracer Mppt with an mt50 meter.
When I bought the boat I moved it from Whilton to harefield Marina over xmas week, running all day no charging problems but wasn't using much power anyway. The boat then stayed at harefield for 3 months on shore power; no problems there.
We set off in early April, 2nd day out I noticed that the Rev counter had stopped working, realised the cause of this was an alternator failure. No problem I just fired up the sterling AC genny and switched on a battery charger to keep the batteries charged til I could get the engine alternator sorted out. Was ok for a couple of days, then at the end of a day's cruising we were just locking up the boat to go to the pub when I noticed smoke billowing out of the electrical cupboard, quickly jumped down the steps and unplugged everything. Smoke cleared to find that the mains leads on one of the battery chargers had burnt out.
Because I panicked and pulled all the plugs I can't be sure what was plugged in where but I suspect that I had the charger and the inverter both plugged in. So now down to one battery charger with no engine alternator.
Eventually got to a boat yard, they couldn't do the job and gave me some numbers of mobile mechanics. Got a new alternator fitted and we're off again. Well we were off for two days until the engine overheated due to a knackered water pump. Called the mechanic to be told it would be a week for parts. Now this was still early April and it was very cold. The squirrel has a back boiler with 4 rads and a colorifier in line, I had already had problems with the 12v pump and eventually had it changed out for a 230v pump. No power, no pump, no heat. I'm considering re plumbing to thermosyphon, but that's a whole different thread.
Had no alternative but to buy a petrol suitcase genny to charge batteries. Had during this time let them go very flat
After having the pump fitted were OK for about 3 weeks then the batteries started to loose power, charge up for a good few hours using the engine alternator and the battery charger via the sterling 230v alternator and started getting less and less life out of them until eventually after a full days charge the low power alarm on the inverter would go off after watching less than an hour af tv in the evening.
So sod it, time to fork out for new batteries.
Originally the boat had 2 x 230ah and 2 x 110ah. I decided to changed them for 3 x 230ah. The day they were fitted I also bought the smartguage and fitted it the next day. That was about 3 months ago so the smart guage has had plenty of time to calibrate itself.
With the guage saying 100% most evenings we have the shoreline fridge and freezer running, the 12v dvr the inverter powering the tv and possibly the DVD player, the 12v tv signal booster and the wifi unit. At most we watch 2-3 hours tv on the odd occasion 4 hours by the time we go to bed the guage is usually reading 55-60% the voltage reading on the smartguage and solar guage read the same.
My concern is that the inverter, though it is working may actually be faulty and is pulling to much current. When I removed the fire damaged charger I took it apart, the earth wire in the lead and all the earth wires inside the unit were fried. I think that when we had the fire the inverter and charger created an earth short. Is it possible for the inverter to appear to be working properly for 4 months but still have a fault. Is there any way to test this?
Tonight I plan to charge up fully, nearly at 100% now and the petrol genny has a full tank. I'm going to leave it charging until is runs out.
I'm then going to turn off everything, fridge freezer, the lot, and only have the tv and inverter on and check the guage every 1/2 hour.
Of course it could just be that I'm using too much juice.
Oh buy the way the tv has a sticker on the back that says it is 110-230v 1.2a 63w and it is 230 only, there is no inline transformer
Phew!
