Days Won
12
Posts posted by GUMPY
Don't forget the fuel tank needs pressure testing and having a hatch that will need a good seal is going to make this more difficult.
Never had an inspection hatch on any of my boats but have always had a decent drain at the lowest point of the tanks.
Never had much water in the tanks either. Maybe pint or so in 30 years.
2 hours ago, DandV said:
4 days up and 4 days back is very compressed for a delightful waterway.
Especially if it goes on SSA at any point 😲
- 1
17 minutes ago, Scholar Gypsy said:
In addition to the stoppages list, also worth noting that Cogenhoe lock is shut (power supply problems, via the local campsite), and not clear if there is yet a plan for sorting the issue.
It will go the same way as Titchmarsh, back to manual wind 😲
18 minutes ago, Hudds Lad said:
A slower speed on the router then maybe? Might have a look for a bit and have a test.
The CNC machine at work cut it fine using a router type thing not sure what speed it ran at.
HDPE can be cut with a saw and drilled much like wood can just take it easy. I used a jigsaw to cut my fender hangers. Never had a problem with it melting. My hangers were two pieces bolted together as I only had 10mm thick HDPE. A deburring tool is essential to get rid of the sharp edges.
1 hour ago, IanD said:
Where did you get the HDPE strip from?
I'm afraid most of it came as scrap off cuts from my last work place.
I did get some from on eBay for other projects.
A very useful plastic 🤔
3 minutes ago, IanD said:
That's a good idea, I might do that too 🙂
HDPE is great stuff, hard enough to have strength but soft enough not to damage the paint provided all edges and corners are rounded off with a deburring tool.
- 1
His barge designs are excellent 😎
The joys of SSA
I do miss the river but not the SSA 😲
I see @blackrose is going nowhere on his boat for a while 😉
8 minutes ago, jacko264 said:
The original rubber would have a couple of slots in the top to allow water to pass down below and out of the drains.
I don't have the boat anymore so can't do a picture😲
- 1
45 minutes ago, IanD said:
That's the well-hidden problem with external antenna connections on lots of routers...
I guess it's due to the fact that B42/48 and N78 are all in the same frequency band.
My Huawei says 5g only on the external ports but looks like in reality it means 3.5ghz band. Never seen it expressed as channels before.
Question is do the lower frequency 4g channels use the internal antennas when external antennas are connected?
9 hours ago, ditchcrawler said:
And is there sufficient energy to run a heating system in a Narrowboat or only 3Kw ish?
You generally only need 5kW to run a heat pump and heat a house so 3kW would be enough to run a heat pump to keep a boat warm.🤔
- 2
1 minute ago, MtB said:
The practical solution is to charge all boats on the water £20 a night to moor anywhere out on the towpath.
It has to be more than the cost of a full time mooring in that area divided by 365.
£15 would be more reasonable outside London.
I found a fault!
Whilst is supports most bands on its internal antennas on external antennas only B42 and B48 on 4G and N78 on 5G are supported. So not much use on 4G if you need external antennas.
Found this on eBay.
https://www.ebay.co.uk/itm/276346684524?
Seems a good bit of kit and small.
Can @IanD find a fault with it to stop me getting one 🤔
My old system was a din mount as well, I just fitted it in its place using a blanking panel and used din to cable adapters where required.
Possibly not suitable for the OP but it worked for me, twice and might suit someone else looking for ideas.
I got bored with rubbish radio reception and fitted a Nobsound It has line in and BT. I streamed stuff off my phone or ran it from the TV output.
Worked very well just like a large BT speaker 😉
There are lots of Nobsound units on the market each slightly different 🤔
If you have an L3 Farmers Field mooring and your boat is away from the mooring you do not have to pay cart. For years I only paid for 6-7 months when my boat was on the mooring from October to March/April. I would cancel and get a refund on the BW mooring licence in March/April and go boating. Take out a new one the next October when I returned.
Don't think the law has changed as far as that is concerned.
System has been up and running for a while now. Teamviewer flagged it as a commercial use which I have now got rescinded so have full access again.
One point to note is that on Android 10 remote access needs confirmation at the remote terminal😟
I am therefore running Android 7 which means I have to stay with Victron Connect V5 as V6 requires Android 8 or later.
Improving onboard Mobile communications
in Boat Equipment
I ran mine with one of these:
Step Up Converter,KUNCAN 5V to 12V 1A USB Step Up Voltage Transformer DC Power Cable with Barrel Jack Booster Module https://amzn.eu/d/ffrCr6c
Needs a 2 amp usb socket to run it.
