Skip to content
Wiring an alternator
Featured Replies
#1
Just bought an old narrowboat, the only thing being, the electrics were incompletely reconnected following engine overhaul.
The electrics are very basic - 2x12 volt batteries, isolating battery switch (breaks positive feeds) can be switched to either battery/both or none. Just a few 12v circuits (horn. lights, water pump, bilge pump and headlight). Starter (via a Bosch key switch) and charging circuits.
The problem is the previous owner had replaced the old Bosch alternator with a Leece-Neville one, and I need a bit of help identifying how to wire the alternator up.
I know the boat was in regular use until illness forced its' sale, and that the electrics were no problem.
There are 3 terminals on the alternator labelled REG, POS and NEG. ( I gather these are equivalent to D+, B+ and B-)
The alternator has an internal regulator, which has one wire connected to the REG terminal. The other is "floating". I assume it was removed from one (NEG?)of the terminals when the alternator was disconnected.
There are 2 wires from the starter switch, a thin one via the warning lamp, which I would think connects to the REG terminal. There is a thicker wire back to the switch which I am not certain about (REG or POS I would have thought). There is also a thick battery feed- type wire, which I am not sure whether it is a feed or earth.
Any help would be gratefully received.
Thanks
#2
A photo would probably help.
#3
There will be people who can offer more complete advice than me on this but I'm not really clear as to the actual situation. It sounds as if you have your alternator cover off for some reason but I'm not sure why if there are markings on the terminals. You only need your main battery positive for charging the battery bank and then your D+ for auxiliary electrics. There is a field wire and often a tachometer connection but I seem to recall you don't need to mess with the Field unless you're planning on fitting a smart charging system.
The main thing is that you can get a charge to your batteries via the alternator and without any significant voltage drop. The D+ will then supply auxiliary circuits. Some alternators have negative pole and some positive.This may help:
http://www.prestolite.com/pgs_products/specs.php?item_detail_id=29021&item=BLP2334GH&product=ALTERNATOR
Thanks
#4
Or a model number.
Tony
#5
I am wondering if the thicker wire back to the starter switch is to do with the heater plug supply as there should be no reason to take an earth from the alt into it?
  • Author
#6
OK, Here is a basic wiring diagram:
A view of the connection end of the alternator can be seen in this picture. although the regulator fitted to mine is a 12v one.
This Prestolite drawing indicates the "free" wire leaving the regulator is the excitation lead, which I would have thought meant it connecting to the wire from the warning light. However both these leads to have ring connector terminators (unlike the regulator in the Prestolite pictures), which probably means they attach to the alternator post connectors.
I am also confused by the "spare" battery-type lead which could be either a negative bonding lead, or a positive feed lead, as one of the ring connectors is too small to be connected to a mounting bolt.
Once again thanks for any help.
Edited by Phredd
#7
I think Gibbo wanted a picture of YOUR alternator so we can see the size and colours of those lose wires etc.
#8
Looking at it simplisticly, there needs to be a connection from B+, P ositive, to the batteries somehow. Is the spare lead though it is black long enough to reach from the P to the starter motor +ive or isolator? The warning light takes a live from the ignition and the other (live when alt is running hence the light extinguishes) from D+ or seemingly R in your case. The AC connection A is equivalent to W on other alternators and is for the varying live feed to the tacho. Many modern boats use insulated return (marine) alts so there has to be a connection from B-, negative, to the batts or where the starter is grounded or, similar.
Someone with expertise on your alt will be along soon (to confuse you)!
  • Author
#9
Not in a position to get a photo of my alternator - my camera is abroad with my daughter at the moment!
However diagram indicates actual colours of cables, and relative thickness's. Basically thin red cable from lamp - same thickness as the green starter energiser cable from key switch, and a much thicker brown cable (about third thickness of main battery cables) from key switch. The "floating cable" is standard main battery cable. The cable running from battery isolator switch to key switch is same size cable as the brown cable, but is brown/white.
Hope that makes sense.
Thanks
Don't worry - I am already confused enough - never had any problems when dealing with Lucas alternators - just connect the plug!
Phredd
#10
It looks to me like...
The flying lead from the alternator connects to the thin red Warning Light wire. Perhaps the previous owner connected them together with a nut and bolt?
The Thick Brown wire goes to P
The "floating" cable goes from N to a suitable stud/bolt/fixing on the engine.
I don't like the fact that the charge has to travel through the ignition switch to get to the batteries - that's two switches and a total of 7 connections between alternator and batteries. I'd be very tempted to remove the thick brown wire from the ignition switch and reconnect it directly to the ammeter.
I'm sure someone who knows Leece Neville alts will be along in a moment and correct me if I'm wrong about the connections.
Tony
#11
Tony is spot on with his wiring.
As for the alternator output going through the ignition switch and ammeter.... That will achieve a few things.....
At the abosolute best it will result in completely shit charging.
At worst it will result in a blown alternator, a fire or melted wires.
#12
Now I've seen the picture. Just like prestolite make what used to be the lucas A127, this one was originally motorola. The yellow lead is a sense lead, the picture shows it on B+, you will want it connected to one of your wires which will come direct from the battery. The "reg" terminal is D+, there is PROBABLY a diode trio under there.
#13
Snib - the Prestolite drawing that the OP linked to here names the yellow lead as "Excitation". So shouldn't it connect to the warning light as I suggested?
Tony
edited for the correct link
Edited by WotEver
#14
Tony
I'm not so sure even Prestolite know. Their own wiring diagram (http://www.prestolite.com/productinfo/alternators/8AR2169F/8AR2169F_wiring.jpg) shows normal D+ to the warning lamp as usual, it also shows the yellow wire to a lamp and then the ignition switch. On its way it goes through something else that is unclear.
PS. The ones I've wired up have indeed been done with the yellow wire to the warning lamp and they worked properly. I wonder if the yellow wire is just paralleled up to D+?
Edited by Gibbo
  • Author
#16
Glad I'm not the only one who is confused!
Talked to someone who had helped the prvious owner before he was taken ill, and he "thinks" he seems to remember that the yellow lead was indeed, as Gibbo says, wired to the Reg post, along with the red wire from the lamp. Also the brown wire from the switch attached to the POS post.
From what I gather from the above posts am I right in thinking the brown wire should be removed from the switch and wired to the switch side of the Ammeter, leaving the other lead from the ammeter to switch intact?
Sorry to be a PITA about this.
Thanks
Edited by Phredd
#17
That's what I was proposing, yes. So you'd end up with two wires on the switch side of the ammeter; one direct to the alt and one to the switch.
Tony
Talked to someone who had helped the prvious owner before he was taken ill, and he "thinks" he seems to remember that the yellow lead was indeed, as Gibbo says, wired to the Reg post...
Actually, Gibbo said that he wired the yellow lead to the warning lamp, as I suggested. Snib (who also knows a lot about these things) thought it should go to a battery connection. However, the wiring diagram does indeed suggest that both wires could be connected to D+.
Have you tried emailing Prestolite?
Tony
#18
If the yellow lead is a sense lead and / or field supply then connecting it to D+ will just give you a machine sensed alternator. Give me a minute to check my catalogues.
#19
Unable to find any info on this one. If the yellow has been connected to D+ then clearly it does no harm to put 12V on it. Based on nothing more than my experience of American alternators I would suggest it's best to read "excitation" as "enable". The reg may or may not sense on that yellow lead as well and I'm afraid that without having it in my hand I'm not willing to venture any further opinion. Arnot may be the man for this.
Recently Browsing 0
Account
Navigation
Search
Search
Chrome (Android)
  3. Adjust your preference.
Chrome (Desktop)
  2. Select Site settings.
