Guest Posted May 31, 2017 Report Share Posted May 31, 2017 9 hours ago, system 4-50 said: and where have you put the bodies? If I tell you I will have to K. .................... Link to comment Share on other sites More sharing options...
DHutch Posted May 31, 2017 Report Share Posted May 31, 2017 On 2017-5-30 at 13:48, FadeToScarlet said: I lifted up a pipe that had fallen from a bridge over the BCN and was blocking the cut using a cable puller. Turns out there was a 132,000 volt live cable inside it, supplying many streetlights on the M6, and it earthed itself very spectacularly with much flames and smoke as I lifted it up. Ended up calling out the fire brigade and CRT anyway to turn it off first! Bloody hell! Well I am glad you are ok. Link to comment Share on other sites More sharing options...
DHutch Posted May 31, 2017 Report Share Posted May 31, 2017 Assuming it was reasonably easy to run water down, and the cause was fairly obvious, I would run water down. Often such pounds are well known (poolstock, say) or its a left up paddle. If it wasnt obvious I might then email to let them know I had done so, if it was a big job for some reason, or failed to fill, i would then ring and either work while waiting for them to arrive or not as appears sensible. Daniel Link to comment Share on other sites More sharing options...
