Kieron G Posted February 4, 2016 Report Share Posted February 4, 2016 Hi, hope some one can help. I've removed the valves from the cylinder heads on my flat twin to try and sort a problem I've got with worn valve stem seals. The seals are retained in a kind of removable steel 'top hat' which is held down by the inner valve spring. The cylinder head which I think has been passing oil has synthetic plastic rings as seals inside this top hat. But the other head has what looks like hemp / string packed in. I don't know if any other engines share this system. I can't find any parts or literature for this engine and was wondering if it is possible to buy this 'string', pack it in to the retainers and create my own seals ? Thanks. Link to comment Share on other sites More sharing options...
SUIGENERIS Posted February 4, 2016 Report Share Posted February 4, 2016 Hi. Kieron I am guessing from your boat name and the engine description you are running a Coventry Victor. HDW 2 which was marketed as a "Victor Vixen" engine. They were fitted into a lot of Board of Trade approved lifeboats. There were indeed "valve guide seal pads" in that design of engine. The part number was N 1176/A and there used to be a site on the web for Coventry Victor with some spares available. Whether that still exists I have no idea. If not available I guess you just have to bodge it with some caulking string. I do have a servicing manual and parts list of about 80 pages with quite good drawings and could perhaps get it copied for you if it helps. Let me know. via a personal message. Cheers. Mick Link to comment Share on other sites More sharing options...
RLWP Posted February 4, 2016 Report Share Posted February 4, 2016 Maybe new 'top hats' could be made to carry modern stem seals? Richard Link to comment Share on other sites More sharing options...
Kieron G Posted February 4, 2016 Author Report Share Posted February 4, 2016 Thanks Mick & Richard. Yes the Coventry victor site hasn't been live for some years now unfortunately. I guess if I went some where with a selection of seals I might find a match for the synthetic ring type 'modification' or as Richard suggests a replacement. String caulking is a good description of what appears to be in there now. I didn't know that these engines were fitted in life boats. I think that's where mine might have come from because it has official looking insurance inspection stamps on the casings. Link to comment Share on other sites More sharing options...
Kieron G Posted February 4, 2016 Author Report Share Posted February 4, 2016 Mick , have sent you a personal message re bump & valve clearances. Thanks. Link to comment Share on other sites More sharing options...
