tonyreptiles Posted March 21, 2006 Report Share Posted March 21, 2006 I have an eberspacher which heats my radiators but not my water. I don't have a cli=ue how it works apart from that I know it uses diesel and comes on when I pull a switch. A couple of questions if I may. 1. Are they expensive to use. I know they use diesel but how much? Does it use electricity too? How does the cost compare with using coal/wood in my stove. 2 Can it be set up to heat my water too? 3. What's your opinion on them? Cheers all TR Link to comment Share on other sites More sharing options...
bottle Posted March 21, 2006 Report Share Posted March 21, 2006 Tony Go to this link all the info you require Link to comment Share on other sites More sharing options...
Gary Peacock Posted March 21, 2006 Report Share Posted March 21, 2006 They are our standard fit and we have very little problems with them. For very serious domestic use on large boats there are better and more expensive solutions but for the average narrowboat providing care is taken with the correct fuel they are very good. Link to comment Share on other sites More sharing options...
tonyreptiles Posted March 23, 2006 Author Report Share Posted March 23, 2006 Cheers Both. TR Link to comment Share on other sites More sharing options...
pagan witch Posted March 26, 2006 Report Share Posted March 26, 2006 We are liveaboard on an ex Black Prince 62ft boat that uses an Eberspacher for hot water and radiators. It does a brilliant job of heating 3 decent sized radiators and providing copious hot water. I'm sure that it is possible to make it heat water as well as radiators but this may mean you need to invest in a new hot water tank. My web site (please insert the www bit and the dot co.uk at each end) at canalpages, follow the link to 'going liveaboard' tells you much about what we are up to and has a section on the way our boat is plumbed including a schematic that may help. It is a pretty standard layout. We have - and I'm sure it could be altered if I could be bothered - the opposite problem. Our engine gives us masses of hot water but will not feed the radiator. A look at the schematic will show you that the Eberspacher circuit goes through the tank and the rads - hence providing heat to both, but the engine only goes to the hot water tank. Ideally what I'd like is for both to do both. Maybe one day I'll get around to it. Link to comment Share on other sites More sharing options...
