Moorings Posted June 21, 2011 Report Share Posted June 21, 2011 Having recently bought a 5 year old boat (on the original batteries) I decided to check the electrolyte levels. All were fine and didn't need topping up, except for one of the four 110 Ah leisure batteries. This was extremely dry and took at least 500 ml into one cell alone to get the level above the plates, at which point I suspected a leak and decided not to top up the other cells until I'd consulted the knowledgeable here! However, the area around the battery remained dry and there is no sign of acid damage to the paintwork in the area. So, what might be happening? All the connections are firm, 14.3V is present at all four leisure battery terminals when being charged via the Victron or the alternator, so why is this one battery so dry? Link to comment Share on other sites More sharing options...
WotEver Posted June 21, 2011 Report Share Posted June 21, 2011 So, what might be happening? All the connections are firm, 14.3V is present at all four leisure battery terminals when being charged via the Victron or the alternator, so why is this one battery so dry? Does that battery have the connections to the rest of the boat on it? Is it at one end of the bank? Tony Link to comment Share on other sites More sharing options...
Moorings Posted June 21, 2011 Author Report Share Posted June 21, 2011 Does that battery have the connections to the rest of the boat on it? Is it at one end of the bank? Tony It is indeed at one end of the bank - the one furthest away from the connections to the rest of the boat. Ken. Link to comment Share on other sites More sharing options...
WotEver Posted June 21, 2011 Report Share Posted June 21, 2011 ... the one furthest away from the connections to the rest of the boat. Odd - I would have expected it to be the other end. Regardless, your battery wiring is incorrect. At the very least the two connections to the boat should be at diaginal opposites of the bank. The negative connection going to the hull from one battery, and the positive connection going to the isolator from the battery at the other end of the bank. See here for more esoteric solutions, and an explanation as to why yours is wrong. As for the 'dry' battery - top it up and keep your eye on it. Tony Link to comment Share on other sites More sharing options...
Moorings Posted June 21, 2011 Author Report Share Posted June 21, 2011 Odd - I would have expected it to be the other end. Regardless, your battery wiring is incorrect. At the very least the two connections to the boat should be at diaginal opposites of the bank. The negative connection going to the hull from one battery, and the positive connection going to the isolator from the battery at the other end of the bank. See here for more esoteric solutions, and an explanation as to why yours is wrong. As for the 'dry' battery - top it up and keep your eye on it. Tony Thanks for the link. It is indeed wired as per Gibbo's Method 1 in that link and I can now see that it is wrong. What I've also just noticed is that the charging cables are connected to the battery adjacent to the dry one, not to the terminals where the load is taken from. Surely that can't be right? (To clarify, if we have batteries numbered 1 to 4 connected in parallel where 4 is the dry one, then the load to the boat is connected to 1 and the charging cables to 3 if that helps). Ken. Link to comment Share on other sites More sharing options...
WotEver Posted June 21, 2011 Report Share Posted June 21, 2011 Surely that can't be right? No it's not. Folk sometimes think that they'll "share the load around" but Gibbo explains why that's wrong. Your batteries will thank you for correcting it all Cheers, Tony Link to comment Share on other sites More sharing options...
Robin2 Posted June 21, 2011 Report Share Posted June 21, 2011 It is indeed at one end of the bank - the one furthest away from the connections to the rest of the boat. Ken. Perhaps it was moved to its present position before you took delivery of the boat? Link to comment Share on other sites More sharing options...
