Dorman Posted September 10, 2010 Report Share Posted September 10, 2010 I have 2 listers l am rebuilding with the proposal to place one in a tug shell some time in the future which will be built around it. I have an offer on a remote 1.2 blackstone type gearbox--this is my quandary. The shell l would like we feel needs to have limited draught due to our experiences with the current deep draught boat. What would the min prop be reasonably on a 1.2 gbox with this lister 1200rpm max? My thoughts would be to go 1.1 with shallow draught boat--or am l wrong? Can the gearbox internals be changed as this is a good offer. Cheers Simon Link to comment Share on other sites More sharing options...
mykaskin Posted September 10, 2010 Report Share Posted September 10, 2010 I have 2 listers l am rebuilding with the proposal to place one in a tug shell some time in the future which will be built around it. I have an offer on a remote 1.2 blackstone type gearbox--this is my quandary. The shell l would like we feel needs to have limited draught due to our experiences with the current deep draught boat. What would the min prop be reasonably on a 1.2 gbox with this lister 1200rpm max? My thoughts would be to go 1.1 with shallow draught boat--or am l wrong? Can the gearbox internals be changed as this is a good offer. Cheers Simon You'll be fine on a 2:1 box on this engine. You can always increase the pitch or blade area on a prop to match if you don't have a lot of room to swing a large diameter. It's only 16 HP when all is said and done. Mike Link to comment Share on other sites More sharing options...
Proper Job Posted September 10, 2010 Report Share Posted September 10, 2010 I'm no expert with prop sizing but 16hp @ 1200rpm give 70 ft lbs of torque (doubled if via a 2:1 box) I would have thought a prop in the 18" to 20" range would be easy to achieve. Possibly a lot smaller with and increased blade area. Link to comment Share on other sites More sharing options...
casper ghost Posted September 10, 2010 Report Share Posted September 10, 2010 Depends what you call a shallow draft. My boat has only 21" draft and I have an 18x19 propeller. I expect you would need something slightly bigger but not by much. Crowthers can make a prop to fit but I was lucky and found mine second hand. Casp' Link to comment Share on other sites More sharing options...
