bluewarrior567 Posted July 27, 2010 Report Share Posted July 27, 2010 Hi Once we,ve had the boat blasted, we obviously need to paint her. Would you recommend bitumen or coflex on the hull? Has anyone a good recommended paint which they have used either as a primer, undercoat or top coat. What is the best paint to use on freshly blasted steel? Cheers Link to comment Share on other sites More sharing options...
Grace and Favour Posted July 27, 2010 Report Share Posted July 27, 2010 HiOnce we,ve had the boat blasted, we obviously need to paint her. Would you recommend bitumen or coflex on the hull? Has anyone a good recommended paint which they have used either as a primer, undercoat or top coat. What is the best paint to use on freshly blasted steel? Cheers I'd use Craftmaster paints - everytime They are expensive - but excellent quality Are you painting the boat yourselves? - If so - have you considered going on a short boat-painting course (Phil Speight does one regularly) Link to comment Share on other sites More sharing options...
kitman Posted July 27, 2010 Report Share Posted July 27, 2010 You need to get something on there quick before it starts to ginger. If the whole boat has been shotblast you might aswell put a two pack primer on there, for instance Blakes EPU. For the hull you could use an epoxy pitch system from a firm like dacrylate, speak to their technical section for advice. Link to comment Share on other sites More sharing options...
Radio-Ga-Ga Posted July 28, 2010 Report Share Posted July 28, 2010 It depends on your budget, working conditions and your own abilty if its got to be DIY, given the opportunity to start from bare metal I'd forget boat paint or any synthetic and go for 2K acrylic, but you need to be experienced with vehicle spraying, or know somebody who is, and is willing to do it. Whatever paint you choose, you need to be ready to get it primed quickly. Link to comment Share on other sites More sharing options...
