blodger Posted October 29, 2009 Report Share Posted October 29, 2009 i think using relay and simple switch is a good idear i was thinking something from maplins small an descreat.my pipe run will be a loop to pass all taps etc with a short 0.5m or less branch of to each tap so when pump it used it charges the hole system with hot for the electrical minded how simple would it be to use a adjustable timed switch ie: press once to start a timed run say 20seconds then system resets till next time? also any recomendations for the pump? I think there would be little benefit to plumbing at each tap depending upon the setup but probably Ting into the tap furthest from the the calorifiier will achieve all that can be achieved without too much complication and increasing costs. Personally I do not see it as optimal to have presumably expensive timed switches since you have to take into account last use, ambient temp, calorifier temp, etc. You could end up stirring up the conrents of your calorifier needlessly diminishing the supply of really hot water. I suppose if the time delay is adjustable by experience it could be set to function as optimally as possible for average circumstances maybe altering between winter and summer? have found this looks spot on? http://www.sparksdirect.co.uk/columbus-pne...vo33ek040hf3bq7 That seems a reasonable price Link to comment Share on other sites More sharing options...
nb Innisfree Posted October 29, 2009 Report Share Posted October 29, 2009 have found this looks spot on? http://www.sparksdirect.co.uk/columbus-pne...vo33ek040hf3bq7 That's the baby, there are ones with the push button exposed rather than recessed, may make it less fiddly to push. Link to comment Share on other sites More sharing options...
blodger Posted October 29, 2009 Report Share Posted October 29, 2009 have found this looks spot on? http://www.sparksdirect.co.uk/columbus-pne...vo33ek040hf3bq7 Do they work on 12v DC though Link to comment Share on other sites More sharing options...
nb Innisfree Posted October 29, 2009 Report Share Posted October 29, 2009 Do they work on 12v DC though Yes, solar pump current is very low. Link to comment Share on other sites More sharing options...
