chris w Posted April 27, 2009 Report Share Posted April 27, 2009 But measure the pressure too BEFORE opening a tap. that will give you the pump's cut-off pressure. After opening a tap (with the pump off) will give you the accumulator's set pressure. Chris Link to comment Share on other sites More sharing options...
denboy Posted April 29, 2009 Author Report Share Posted April 29, 2009 Righto peeps success at last after a lot of cursing and worse ,problem sorted obtained a pressure gauge and put in the circuit and lo and behold the 30 psi pump was putting out 48 psi or 4.2 bar not very good for a 3 bar prv now all i have to do is mop all the stray water out from the nooks and cranny`s Link to comment Share on other sites More sharing options...
alan_fincher Posted April 29, 2009 Report Share Posted April 29, 2009 Righto peeps success at last after a lot of cursing and worse ,problem sorted obtained a pressure gauge and put in the circuit and lo and behold the 30 psi pump was putting out 48 psi or 4.2 bar not very good for a 3 bar prv now all i have to do is mop all the stray water out from the nooks and cranny`s Great news - glad you got there. Although I was on the same track, I think Ditchcrawler and Chris W should share the honours for really coming up with the right answer! Link to comment Share on other sites More sharing options...
