jeb Posted December 4, 2007 Report Share Posted December 4, 2007 Hi I'm going to install led lights throughout the boat. Now the question is what is the difference between a transient suppressor and a voltage buck driver ? Link to comment Share on other sites More sharing options...
chris w Posted December 4, 2007 Report Share Posted December 4, 2007 Hi I'm going to install led lights throughout the boat. Now the question is what is the difference between a transient suppressor and a voltage buck driver ? A transient suppressor will prevent (hopefully) any abnormally high voltages reaching your equipment. A buck driver will provide a constant current to your equipment (LEDs in this case). If you purchase LED bulbs which fit into a standard holder (eg: BAY15D) just ensure they have an on-board voltage regulator and you'll be OK. That way the brightness won't vary as the battery/charging voltage varies. Most are like this nowadays and they also have the advantage that they are not voltage polarised, ie: you can put them into the holder either way round. Chris Link to comment Share on other sites More sharing options...
jeb Posted December 4, 2007 Author Report Share Posted December 4, 2007 A transient suppressor will prevent (hopefully) any abnormally high voltages reaching your equipment. A buck driver will provide a constant current to your equipment (LEDs in this case). If you purchase LED bulbs which fit into a standard holder (eg: BAY15D) just ensure they have an on-board voltage regulator and you'll be OK. That way the brightness won't vary as the battery/charging voltage varies. Most are like this nowadays and they also have the advantage that they are not voltage polarised, ie: you can put them into the holder either way round. Chris Thats great Chris , thanks very much. Link to comment Share on other sites More sharing options...
