Lochwarden
Everything posted by Lochwarden
  1. I think that was the idea 😂 I will check those on my way round the engine, thank you.
  2. No there was no lip on the 1275 A Series for the rocker gasket to sit up against from memory. It was a case of tightening it up enough to provide a seal but not so tight as to not squeeze the gasket out of the sides. Yes, a drop of contact adhesive or gasket goo definitively helps.
  3. Thank you Tony. There’s no oil at all coming from the air filter or breather hose. I’m going to degrease the outside of the engine and drop tray and run it to check for leaks, as you suggest. I remember the cork rocker cover gasket on my old MG Metro being awful to get to line up, so I know what you mean!
  4. I have a 1.5 BMC which is in my boat built in 1990. The engine has recently started leaking oil into the under engine tray. But also oil is trickling out of the oil pressure gauge! I thought it must be the crankcase breather blocked, but I removed the side tappet cover and the breather pipe seems fine. Any suggestions as to why I could be losing oil. It’s not a tremendous amount, but any amount is not desirable!
  5. I once saw someone operating the wheel with a geared down cordless drill with an attachment that fitted on the large square nut in the centre. Always been meaning to try that myself, but never got round to it.
  6. That other group wouldn’t be the 12 volt boating group would it? As on here, there are some very knowledgeable people on there, and some not so knowledgeable as well.
  7. Run your new LiFePO4 in parallel with some LA. A lithium/ Lead acid hybrid set up will negate the need for any fancy charging gadgets and will protect your alternator once the LFP is fully charged and the BMS stops accepting the charge current from the alternator. It’s as simple as that. On my boat I have one 300ah LiFePO4 and 3 x 110ah lead acid in parallel. They work just fine together.
  8. For that price LiFePO4 would definitely be a good choice I think. I paid £1140 for my 300ah LFP. Sounds like a lot of cash for 1 battery, but it should be good for 15 maybe 20 years. Running it in a hybrid set up with 340ah of LA. It’s been a game changer for me on my boat. Been off grid for 6 weeks now, running purely off solar. Can heat my water if I need to, even cook on electric with it occasionally to save on gas. Will be interesting to see how I get on in the winter though, with less sun. Probably have to return to the marina soon 😞
  9. Indeed. Luckily 50amps from my alternator is enough for me, with the 800 watts of solar as well. My boat isn’t very power hungry, with just the fridge, pumps, lighting and occasional 12 volt tv. I do run the 950watt immersion in the calorifier through the inverter sometimes if I’m not running the engine. Don’t think I’d do that with an LA bank!
  10. My own actual build. I recently fitted a 300ah LiFePO4 battery running parallel with 340ah of lead acid. They’re charged with a 75amp alternator and 800 watts of solar. They complement each other perfectly. The LiFePO4 does most of the work, with the lead acid just sitting there on float for the majority of the time and taking the current from the alternator once the LiFePO4 is fully charged. I’m no electrician, but a hybrid system like mine is really simple to set up and can just be left to do it’s thing, with the batteries built in BMS looking after the LiFePO4 preventing over or undercharging. I also have a lead acid starter battery, also charged from the alternator, through a split charge relay. Hope this helps. I agree. My new A127 75amp alternator puts round about 50amps into my hybrid bank. Since I’ve started learning about batteries / 12 volt electrics / methods of charging etc, it’s become a bit of an obsession! An enjoyable one though 😊
  11. Hi, thanks Dave, but I’ve just ordered one from Bowers. £75 with vat and delivery included.
  12. Thank you, it’s all much clearer now.
  13. Thank you Tony, after looking at the diagram it makes sense now. Thank you.
  14. Need a new alternator for my 1.5 BMC. It’s the A127 I need I believe. Just not sure if it’s right hand or left hand fitting I need. Looking at the front of the engine, fan belt end, the alternator is on the left. So silly question, but is it the right hand fitting one I need or left hand. Just seems to be conflicting information as to which one I need, left or right fitting? The obvious answer for me is left hand fitting? Thanks.
  15. That sounds like a good idea, I will have a look today. Thank you.
  16. The operating lever was identical to the old one, and it fitted perfectly. I did partially refit the old one to make sure the new one felt and fitted the same. The old one was replaced as it was leaking fuel.
  17. The lift pump is only a few months old, with very very few hours use, so am assuming it’s ok.
  18. No they haven’t. I think the way forward is to start at the tank, work my way to the injectors then back again, making sure everything is leak free and unblocked.
  19. That would make sense, thank you. I only recently added more diesel as I’ve only had the boat a year and it’s been on a marina for most of that, so perhaps adding new fuel could of stirred up muck and transferred it to the pick up pipe? Thank you, I will look at doing that if all else fails.
  20. I’m certainly not trying to waste anybody’s time, apologies if it seems that way. I was just asking the question again, but listing the things I had done to try and fix the problem, after taking advice from my earlier question. I certainly don’t want to upset anybody. Yes i have tried a longer screw with a locknut, no difference.
  21. It is indeed. It is the wrong fitting, with no locknut. That’s how it was when I got the boat last year.
  22. My 1.5 BMC is revving too hard. I’ve checked for leaks, replaced the fuel filter nearest the engine with new o rings fitted. Checked the small filter under the large hexagon on top of the injector pump, it was totally clean. Slackened the idle screw right off. Removed and replaced the governor body, everything good in there. Engine oil level is normal. Engine doesn’t smoke, just the normal blue smoke at start up. The only way I can bring the revs down to a usable level is to have the engine stop half way out. Any ideas would be very welcome.
  23. Thank you for that explanation Tony, very much appreciated. I will check out your website. Thanks again.
  24. Thanks Tony, your input is much appreciated. Unfortunately even with the damper screw out it is still revving very high. If the small filter underneath the hexagon on the pump is partially blocked, could that cause it to rev high, as the pump tries to compensate for reduced fuel flow? I’m pretty good mechanically but have very limited knowledge of how this fuel pump operates. I only have you guys, and the manual that came with the boat, which as I’ve found out isn’t always correct!
  25. That’s probably my next move. That’s why I was asking whether taking the governor housing off to have a look was a good idea, see if anything is obviously amiss in there? I don’t want to make matters worse though. Although at the moment it’s revving too fast for me to get off the river bank anyway. I know you suggested leaving the governor body alone, but is it possible that something is jammed inside causing the high revs? Is there anything I need to be aware of in removing the governor body? Thank you
