John
Mute point between between maximum pressures and safe working pressures, I thought I had clarified in my posting the reason for fitting a pressure reducing valve and also covered the reasons why. John you are renowned for keeping boat equipment as basic as possible, you have pointed out that the pressure switch is a horrible contraption, which is the very reason I have recommended protecting the calorifier against any over pressure instances occurring. Bearing in mind that this particular calorifier is low rated by modern standards whereby calorifiers are now tested to 5bar (70psi)
You may have found that 14psi is acceptable to you I personally need more than this pressure to run my shower, and to enjoy the means to have a proper shower, that's a personal thing. When I give advice I look at the facts concerning the particular problem and give the best advice possible, not allowing personal preferences to cloud the issue, if it means using a piece of equipment that is out of the norm then so be it, I am advising people who have less knowledge than myself and I take this into account in my recommendations,
Whatever I advise is something I would do for my own use if it be needed. In this particular case if it belonged to me I would protect it as described. Bones will have to decide what action to take, from the varying and obviously confusing suggestions that have been posted. I have tried to keep it as simple as possible and at the same time giving the maximum protection.
